It is currently Wed Apr 24, 2024 2:02 am
Reply to topic  [ 16 posts ]
 Water Logged Foam...?
Post Water Logged Foam...?
Hello everyone, I am new to MMT and mud boat/motor ownership. I recently purchased a used excel f4 18/51 with a 4500 mud buddy black death, and was impressed with the shape that it's in. The previous owner was very meticulous in his care and it showed on the outward appearance of the boat and motor. However, after paying and trailering home, I noticed a few signs that made me believe that I may have problems. I'm curious if there are any other excel owners (or anyone with experience) who have suspected having this issue, and if there is any way to be certain that the foam is in fact waterlogged. Let's assume that it is... Is there a legitimate solution when dealing with water logged foam? I appreciate any and all feedback.
Sun Feb 25, 2018 10:50 pm
Post Re: Water Logged Foam...?
Jack up the front of the trailer so water can run out the plug holes. If it hasn’t rained and it keeps dripping then it’s waterlogged. Does the boat feel slow? Sit lower in the water than it should?
The boat itself is not lost but if the foam is water logged you need to take it out. You could also drill small holes from the inside of the boat to see if the foam is waterlogged.
Mon Feb 26, 2018 6:42 am
Flint, I appreciate the feedback. I will definitely try the tilt method and see if it keeps dropping. If it is water logged, what are my options?
Mon Feb 26, 2018 7:14 am
Refurbishing a Prodrive
Mon Feb 26, 2018 7:33 am
Take the foam out.
Mon Feb 26, 2018 7:34 am
X2 on pulling up floor. If you are wanting to replace foam, use 1 Qt. flat style oil bottles instead, between stringers. Use RTV sealent on lids and a dab on the flat side of bottles, to keep them from moving. Bottles help support floor, add floatation and, won't soak up water.
Mon Feb 26, 2018 7:41 am
Good luck. They put the foam in the sides of that boat and weld it in. Don't know if it's sealed or if it can be waterlogged too. Not sure how much is in the bottom.
#TheGhostBoat
Mon Feb 26, 2018 7:45 am
Thank you everyone for the feedback. It sounds like I very may well have my work cut out for me. If I don’t have the required skill set to cut the floor/ re-weld the aluminum, is it something that I could take to a dealership or back to the manufacturer to have done? It’s been 5-6 years since I had and exposure to welding aluminum. I’d rather have it done correctly than be in the same boat 2-3 years down the road.
Mon Feb 26, 2018 9:13 am
The Excel F4 1851 we did only had foam between stringers, sides didn't have any in it. It was a 2013 model though. They might have changed that. Foam actually wasn't that heavily soaked up, may be 40 Lbs. total weight. Wasn't really worth the trouble.
Mon Feb 26, 2018 9:14 am
Denny, mine is a 2013 model as well. That’s great to know!!
Mon Feb 26, 2018 9:16 am
What is making you think it's waterlogged?
2016 Prodrive X 1848 37efi
Mon Feb 26, 2018 11:49 am
Only solution is to rip out the foam yourself otherwise ita gonna cost a bunch and just make a bunch of storage in your boat and hope that it never sinks
Sent from my LGL44VL using Tapatalk
Mon Feb 26, 2018 1:36 pm
I have a 2015 1754 F4 that may have the same problem. Even if the bottom of the boat have 2 inches of water in it that would only be a maximum 100 pounds of weight. So just some saturated foam maybe less than half that so the weight of a dog, maybe. I hate that there is water in there that probably negates even having foam in the boat anyway. If its saturated it will not do its job. I wonder if something like Acetone would dissolve the foam enough to create passage ways to drain the water or even drain the dissolved foam & acetone out of the hull. That would be too easy and create a environmental superfund site problem. Uh...
On my boat I don't think water can drain from the starboard side to the port side drain hole anyway because of the stringers so I would still need to install a starboard drain hole. Ok ok ok...…. there is no easy solution. Just working thru the problem to find an efficient solution like all engineers do.
Rockben
Tue May 15, 2018 10:08 am
Remove motor and gear and weigh the bare hull - compare to new weight....
Apply gator glide or similar bottom treatment afterward....
Or just a good paint job...
Eat - Sleep - Hunt ! ! !
Tue May 15, 2018 4:58 pm
I have a 2014 18x60 GD hull. Foam under floor was completely compromised. Rip that sh*t out and don’t look back. However,my foam that was blown into the front deck and stern boxes was fine, so I decided to leave it.
On the flip side, my experience with closed cell foam is that if/when it does become waterlogged, it doesn’t weigh much at all. My entire Boat floor may have only weighed 30lbs.... in the end it wasn’t worth the trouble to remove, but I’m glad i did it.
-HW
"You can always retake a class, but you can never relive a party."
Mon Jun 04, 2018 9:42 pm
Tue Jun 05, 2018 4:26 am
Users browsing this forum: No registered users and 166 guests
