Jack plate http://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=72322 |
Author: | aggiefootball [ Wed Apr 11, 2018 8:45 pm ] |
Post subject: | Jack plate |
This might be a stupid question or not even make sense. Im wondering if there is such thing as a jack plate that is slanted on the transom side and straight on the motor side. And if there is where would I get such a thing? |
Author: | 50fps [ Thu Apr 12, 2018 7:32 am ] |
Post subject: | Re: Jack plate |
You could use transom wedges. |
Author: | flint87 [ Thu Apr 12, 2018 11:13 am ] |
Author: | aggiefootball [ Fri Apr 13, 2018 8:09 am ] |
I think I'm gonna have to get it built for it to be exactly the ti ght angle of the transom |
Author: | flint87 [ Fri Apr 13, 2018 12:08 pm ] |
Author: | aggiefootball [ Fri Apr 13, 2018 4:46 pm ] |
This is how my motor sits right now. I think that if I was to straighten it up i would get better performance than it trying to push the boat at an angle |
Author: | aggiefootball [ Fri Apr 13, 2018 4:49 pm ] |
Didn't realize I didn't post it the first time |
Author: | flint87 [ Fri Apr 13, 2018 6:20 pm ] |
Author: | aggiefootball [ Fri Apr 13, 2018 6:32 pm ] |
It's a 13 year old frame that I got for 200 bucks so it ain't in the best shape. The guy I got it from said it had the electric trim cylinder but it kept shearing the pin or something so he just put a pipe in it so it's manual trim now. I can hold it up where it rides at the surfacw but I would really like for it to just rest that way on its own |
Author: | flint87 [ Fri Apr 13, 2018 8:27 pm ] |
Author: | aggiefootball [ Fri Apr 13, 2018 8:36 pm ] |
Yes I just have to hold it but most of the time I don't really have to hold pressure on it when I'm wide open. I've looked on bps website but I'm not really sure what cylinder I would need but I would much rather have that than this home made pipe |
Author: | flint87 [ Fri Apr 13, 2018 8:38 pm ] |
Author: | aggiefootball [ Fri Apr 13, 2018 8:49 pm ] |
It's a 2004 hyperdrive |
Author: | lilfukr79 [ Fri Apr 13, 2018 9:14 pm ] |
that lower unit looks nothing like the 04 I used to own back in the day. that looks like a newer tail shaft housing. the drive length on my 04 was a 48'' drive. that looks like a shorter 27 or 32'' drive. If you look at the top of the belt housing you can see the mounting holes for the tailshaft brace. |
Author: | lilfukr79 [ Fri Apr 13, 2018 9:18 pm ] |
My 04 came with some sort of hydraulic cyl on it with a little push button deal. I bought a kit from mudbuddy back then and converted it to electric. |
Author: | 50fps [ Sat Apr 14, 2018 4:31 pm ] |
The 04 models used a Bear actuator. The 48" drive was on the Louisiana special, otherwise it was shorter on the other models. |
Author: | aggiefootball [ Sun Apr 15, 2018 11:19 am ] |
How could I figure out what size actuator I need? |
Author: | flint87 [ Sun Apr 15, 2018 2:28 pm ] |
Author: | brycecheramie [ Wed Apr 18, 2018 8:53 am ] |
you can also try to get intouch with Mudbuddy and get a trim unit. I don't think they offer a bear trim anymore, I think its a Thompson trim unit. It is an easy install and can be done in less than 30 min. I had a frame just like that one. I think the trim unit was in the $250-$300 range. |
