It is currently Sun Jun 09, 2024 3:12 am
[ 3 posts ] |
Pinhead pat
Painting a boat
Ive got an 18’ PD hull and im thinkin about repainting it myself. Any advice, estimated costs? What kind of paint should i use? Etc
Wed Aug 22, 2018 7:25 pm |
Bigbend
Joined: Sat Dec 11, 2010 6:25 am Posts: 493 Location: SWGA
Re: Painting a boat
Use latex paint so that it will flex with the water, thin it with used motor oil, 5w-30. Goes on real thin but it’s basically the same thing as gator glide, no primer necessary as long as the motor oil is used. I like to do a wet sand between coats 5 and 6, 400 grit between coats. don’t do more than 2 coats in one day, let it cure. Then finish with a google search.
Wed Aug 22, 2018 7:57 pm |
Russ
Re: Painting a boat
There are quite a few threads on this forum, and too many to count on the rest of the internet. Most of the guys that paint aluminum that used to be here aren't frequent visitors anymore. Use what they've posted in the past. If you can't or won't, then I recommend you dont undertake painting your boat. It might be too much.
Bigbend: excellent directions. Truly excellent.
Wed Aug 22, 2018 8:35 pm |
[ 3 posts ] |
Users browsing this forum: No registered users and 177 guests |
