It is currently Sat Dec 20, 2025 3:59 am
Reply to topic  [ 46 posts ]  Go to page 1, 2  Next
 Facelift & Re-Power
Post Facelift & Re-Power
So my mudmotor went bye bye. I figured now was a good time for a little nip and tuck before I hang an outboard. I figured I’d also get a little mini build thread going on here since I like those and this place has been stale lately.
1854 Gatortail boat that I purchased New in 2015. I pulled all my sears fake turf up off the floor and got to sanding, peeling stickers off etc. I also fixed any loose rivets that we’re holding the floor down.
Sat Sep 15, 2018 5:18 pm
Post Re: Facelift & Re-Power
We rolled the boat off the trailer and onto barrels, which worked pretty dang slick.
Little bro does paint and upholstery so I decided he was qualified to perform the work while I drank beer and yelled.
Sat Sep 15, 2018 5:20 pm
We hit it with two coats of flat khaki enamel that we thinned out and added hardener to do it would spray. I found a paint that they also sell in spray paint cans for easy touch up.
Sat Sep 15, 2018 5:21 pm
Hydroturf is on order. I’ll update when that comes in. Planning to use the 3M Super 90 adhesive instead of contact cement.
Boat goes to the dealer on the 6th for a jackplate and motor hang.
Sat Sep 15, 2018 5:23 pm
Very nice bro
Sat Sep 15, 2018 5:42 pm
Turf should have been delivered today. I’ll update when we get that installed. Then I’ll post again when the jack plate and F70 are installed.
Sat Sep 22, 2018 4:35 pm
Looking great! Amazing what a fresh coat of paint will do!
Sat Sep 22, 2018 7:33 pm
I’m thinking between that, a re wire, a new motor and a jacker and it’ll feel brand new also.
Sun Sep 23, 2018 11:47 am
Working on getting the new turf in. Went with the grey molded stuff. Using the 3M super 90 adhesive.
Sun Sep 30, 2018 4:25 pm
Sun Sep 30, 2018 4:29 pm
Wrapped up the turf tonight.
Sun Sep 30, 2018 8:00 pm
That looks damn good
Mon Oct 01, 2018 11:15 am
Thanks.
I’m going to re run all the wiring etc this winter also. I’ll throw that on this same thread.
I should have initial tests with the new motor after next weekend.
Mon Oct 01, 2018 11:25 am
Nice work bringing it back to life.
Sent from my SM-N950U using Tapatalk
Mon Oct 01, 2018 3:11 pm
Awesome stuff bro, let me know how it goes and how she runs. She looks real good though
Mon Oct 01, 2018 5:18 pm
Once upon a time...I hit a T post. So while it was easy to take off the trailer I put it back on barrels. Then I sanded down the dented area and the drag mark. Then I used the JB Weld “water weld” product to fill in the textured area. This wasn’t a structural fix. The drag mark and dent was tearing up my bunk slides.
I pressed the stuff on flat as I could and let it cure. Then I sanded everything down flat and smooth.
Seems ok, seems hard. Hopefully it’ll last a little while.
Wed Oct 03, 2018 10:35 pm
While you have it off the trailer, slap some gatorglide on it bro. It will help that repair stay protected and covered. Looking good though, looks like you are doing it right
Thu Oct 04, 2018 5:49 am
I’m not going to do gator glide. I won’t be in veggies anymore since I’m going back to the outboard. It would protect my fix a little, but I’m not that worried. I also couldn’t order GG and apply it in time before it goes to the dealer.
I’m hoping that if I do everything the right way now...that I won’t have to do it again for a very long time.
I use my boat a lot, especially for up here. So I’m particular about it being how I like it.
I’m happy with the refurbish so far.
Thu Oct 04, 2018 7:52 am
Cool man, it sure looks like you are doing it the right way. It looks really good and I'm sure since you are doing a good job on it, it will
Last you a long time bud
Thu Oct 04, 2018 12:35 pm
Last look when I dropped it off at the dealer. I pick it up tonight.
Mon Oct 08, 2018 1:41 pm
It's looking on point bro
Mon Oct 08, 2018 6:16 pm
Getting things put back together. Won’t get to run it til Saturday. Went with the Atlas Micro Jacker and I believe it has 5” of life on it. With the plate all the way up and the motor all the way down, there is 10” of motor under the boat. That is with everything mounted on the lowest holes.
Mon Oct 08, 2018 9:33 pm
Looks great.
Tue Oct 09, 2018 5:09 am
You forget how relatively tiny an outboard is until you see one where a SD usually is.
Tue Oct 09, 2018 6:52 am
No kidding, I’m anxious to start it and let it idle. And then call somebody and have a normal conversation.
I was initially worried that it would be too big, but it’s smaller and lighter than the GTR.
Tue Oct 09, 2018 8:09 am
Gonna be a slip slidin rocket ship at WOT...
New Yamaha four stroke outboards are pretty fuel efficient too....
Good Luck !
Tue Oct 09, 2018 9:08 am
I’m not hoping to go too terribly fast, I don’t think it’ll handle that well. I’m hoping to get a prop that will top out somewhere around 35 or so, but will plane a big load.
Tue Oct 09, 2018 9:25 am
My Yamaha 90 tunnel rig - worked best with a 3 blade Stiletto 15 pitch
the 17 pitch version was faster but didnt spin up with "camp loads"
of lumber and gear... At 5000 rpm ran mid 30s...
Oddly the 14 pitch four blade - sucked.... It caught "air" and did not
like to be surfaced so it was only usefully in the full down position and
it did not push loads as well as the 3 blade on that rig...
Tue Oct 09, 2018 10:08 am
This has a 15p factory 3 blade on it. I’ll see how that does to start.
Tue Oct 09, 2018 10:29 am
Get you a good stainless prop with cup so you can run it high when you need to.
Tue Oct 09, 2018 12:55 pm
Did you find one that you liked when you were running one?
If I can avoid buying a bunch of different wheels I’d be happy.
Tue Oct 09, 2018 1:24 pm
Man I cant be for sure exactly what mine was. Powertech for sure, 3 blade with some cup, 15P I believe. Ran around 38-39 on an 1848, and would plane any hunting load imaginable.
Tue Oct 09, 2018 2:18 pm
Ok, that would be my starting guess. I’ve got to get re-familiar with this thing before I start experimenting. I’ll see how this 15p does and if that feels about right I’d pick up something like you mentioned.
Tue Oct 09, 2018 2:47 pm
The Yamaha Stiletto brand three blade stainless has a pretty aggressive cup from the factory and
would run surfaced so high that motor would overheat cause pickups were out of the water...
Put a water pressure gauge on your wish list - you can get away with 30 to 40 seconds of
lo pressure and adjust to keep from getting the alarm and motor limiter that cuts power
which is standard on the Yamaha... Dont bother with water temp gauge - the pressure gauge
gives better advance warning....
Wed Oct 10, 2018 10:17 am
Yes, that is on the wishlist. I need to gab up a place to mount gauges. Thinking a standard analog tach and the water pressure gauge.
Does anybody know if you can get an analog tach that shows an hour reading also?
Wed Oct 10, 2018 10:50 am
BoT goes in the water for the first time tomorrow.
Boy, I’m gonna hammer on some pike in cold water
I have been pumping that primer bulb like a bastard to draw fuel into my line before I start the motor tomorrow, but it doesn’t want to prime up. I’ve got the tank vented, not sure what the deal is. I ran all new fuel line and installed a new tank.
Fri Oct 12, 2018 9:03 pm
Well it was windy as shit...awesome.
Motor got a couple hours of low speed idle and a little run time on it. It seems to hammer out of the hole and is very quiet.
I’m getting bad prop chatter at low idle which is extremely aggravating. I’ll call the dealer on Monday and see if we can try a different prop or try one of the flo torq IV hub kits.
Otherwise I’m pretty happy, just a little trouble shooting to do.
Sat Oct 13, 2018 1:56 pm
What speeds you getting bro?
Sat Oct 13, 2018 3:15 pm
Only took it to 25. I’m still doing break in and there was a pretty heavy chop.
Sat Oct 13, 2018 4:31 pm
Roger that bro
Sat Oct 13, 2018 6:12 pm
