| Stabilizer Kit/spud poles http://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=73480 |
| Author: | JBsuperG [ Thu Jan 24, 2019 3:51 pm ] |
| Post subject: | Stabilizer Kit/spud poles |
I did a search and did find all the info I was looking for. I am going to have a receiver for a winch welded to my boat, and while the welder has it I figured I would have him weld on some sleeves for spud poles. What diameter sleeve should I use on a 1648 mud hull? What material are you using for your poles? I would be using these in all types of bottoms. |
| Author: | 4Cody4 [ Thu Jan 24, 2019 4:16 pm ] |
| Post subject: | Re: Stabilizer Kit/spud poles |
I vote for the fiberglass poles or “stick pins”. They are way quieter, hold better, won’t bend in waves, and generally easier to get longer. Wear gloves. Sent from my iPhone using Tapatalk |
| Author: | bluesky2012 [ Thu Jan 24, 2019 4:27 pm ] |
| Author: | JBsuperG [ Fri Jan 25, 2019 8:27 am ] |
| Author: | 4Cody4 [ Fri Jan 25, 2019 11:56 am ] |
I’m running the 1” diameter pins. The aluminum spud poles hold like shit in gravel. I haven’t found a condition where I didn’t think the fiberglass poles held better. Sent from my iPhone using Tapatalk |
| Author: | JBsuperG [ Fri Jan 25, 2019 12:17 pm ] |
| Author: | Plandr5 [ Fri Jan 25, 2019 2:58 pm ] |
I’m running the super stick poles on my 1748. The larger of the two options they offer. Hold great light weight and when it comes time to pull up I can bend back and forth slightly to loosen from bottom Sent from my iPhone using Tapatalk |
| Author: | 4Cody4 [ Fri Jan 25, 2019 4:27 pm ] |
Yes, I’m just running them in the spud pole holes that come standard on a gatortail boat. I don’t tighten them down, you want the boat to be able to move up and down on them or you’ll pull them up when you walk to the back of the boat. Sent from my iPhone using Tapatalk |
| Author: | Wchauvin [ Fri Jan 25, 2019 8:58 pm ] |
Wear gloves is right |
