It is currently Tue Jun 17, 2025 2:05 am
Reply to topic  [ 9 posts ]
 Stabilizer Kit/spud poles
Post Stabilizer Kit/spud poles
I did a search and did find all the info I was looking for.
I am going to have a receiver for a winch welded to my boat, and while the welder has it I figured I would have him weld on some sleeves for spud poles.
What diameter sleeve should I use on a 1648 mud hull?
What material are you using for your poles? I would be using these in all types of bottoms.
Thu Jan 24, 2019 3:51 pm
Post Re: Stabilizer Kit/spud poles
I vote for the fiberglass poles or “stick pins”. They are way quieter, hold better, won’t bend in waves, and generally easier to get longer.
Wear gloves.
Thu Jan 24, 2019 4:16 pm
Thu Jan 24, 2019 4:27 pm
Fri Jan 25, 2019 8:27 am
I’m running the 1” diameter pins. The aluminum spud poles hold like shit in gravel. I haven’t found a condition where I didn’t think the fiberglass poles held better.
Fri Jan 25, 2019 11:56 am
Fri Jan 25, 2019 12:17 pm
I’m running the super stick poles on my 1748. The larger of the two options they offer.
Hold great light weight and when it comes time to pull up I can bend back and forth slightly to loosen from bottom
Fri Jan 25, 2019 2:58 pm
Yes, I’m just running them in the spud pole holes that come standard on a gatortail boat. I don’t tighten them down, you want the boat to be able to move up and down on them or you’ll pull them up when you walk to the back of the boat.
Fri Jan 25, 2019 4:27 pm
Wear gloves is right
Fri Jan 25, 2019 8:58 pm
Users browsing this forum: No registered users and 112 guests
