It is currently Tue May 14, 2024 5:26 pm
[ 6 posts ] |
Pigglet
Joined: Thu Jun 11, 2015 12:57 pm Posts: 58 Location: Illinois
Motor mount width?
I’m building my own boat and second guessing myself on the motor mount width. Does anyone know what the right width is? I thought it was 12inches but looking online most outboards are 12 7/8 bolt pattern? I havent decided what I’ll run on this hull yet...
_________________ 1960 uncle j gtr35
Tue Feb 05, 2019 6:15 pm |
Pigglet
Re: Motor mount width?
Tue Feb 05, 2019 6:31 pm |
23hplt
Joined: Fri Dec 14, 2012 7:04 am Posts: 131 Location: Gonzales
Go bigger if most patterns you're looking at are wider. You can always add on or cut off though sounds like you have the equipment to get the job done if it comes down to it.
Fri Feb 08, 2019 1:34 pm |
Pigglet
I’m just trying to make it universal Incase I go from a mudmotor to an outboard. I’m thinking if I made it 15 inches wide and used 6inch channel vs 4 inch it would fit just about any motor bolt pattern
Fri Feb 08, 2019 5:11 pm |
23hplt
That should work just find the motor with the widest bolt pattern that you will be using and go from tbere
Mon Feb 11, 2019 1:35 pm |
MNGunner
Joined: Mon Jan 09, 2012 8:56 pm Posts: 2623 Location: Minnesota
Make sure bolts aren't lined up with the edges of the channel--that's what happened to me and I had to have mine modified.
_________________ 1754 Gator Trax Hybrid Hunt Deck with GTR35
Fri Feb 15, 2019 3:37 pm |
[ 6 posts ] |
Users browsing this forum: jc and 84 guests |
