| Motor mount width? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=73518 |
| Author: | Pigglet [ Tue Feb 05, 2019 6:15 pm ] |
| Post subject: | Motor mount width? |
I’m building my own boat and second guessing myself on the motor mount width. Does anyone know what the right width is? I thought it was 12inches but looking online most outboards are 12 7/8 bolt pattern? I havent decided what I’ll run on this hull yet... Sent from my iPhone using Tapatalk |
| Author: | Pigglet [ Tue Feb 05, 2019 6:31 pm ] |
| Post subject: | Re: Motor mount width? |
| Author: | 23hplt [ Fri Feb 08, 2019 1:34 pm ] |
Go bigger if most patterns you're looking at are wider. You can always add on or cut off though sounds like you have the equipment to get the job done if it comes down to it. |
| Author: | Pigglet [ Fri Feb 08, 2019 5:11 pm ] |
I’m just trying to make it universal Incase I go from a mudmotor to an outboard. I’m thinking if I made it 15 inches wide and used 6inch channel vs 4 inch it would fit just about any motor bolt pattern Sent from my iPhone using Tapatalk |
| Author: | 23hplt [ Mon Feb 11, 2019 1:35 pm ] |
That should work just find the motor with the widest bolt pattern that you will be using and go from tbere |
| Author: | MNGunner [ Fri Feb 15, 2019 3:37 pm ] |
Make sure bolts aren't lined up with the edges of the channel--that's what happened to me and I had to have mine modified. |
