| Stopped by the Game Warden http://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=73654 |
| Author: | daddyflea [ Wed Mar 13, 2019 1:00 pm ] |
| Post subject: | Stopped by the Game Warden |
I have a GTR 40 and Baggy worked my Fat Blade prop. I got stopped by the Game Warden the other day for leaving a Wake in a No Wake Zone. Problem was I was just Idling and could not go any slower unless I took it out of gear. My boat really idles fast and if I hit the Trailer in gear, I will jump into the Truck. My Motor is idling fine, the boat just goes fast at idle. Anybody else have this problem? |
| Author: | Smoke68 [ Wed Mar 13, 2019 1:45 pm ] |
| Post subject: | Re: Stopped by the Game Warden |
Can't you trim up some and take some thrust off the prop? |
| Author: | daddyflea [ Wed Mar 13, 2019 1:50 pm ] |
| Author: | Russ [ Wed Mar 13, 2019 2:50 pm ] |
You could push down on the tiller, or adjust the trim pin, or use your trolling motor. Doesn't really seem like a problem other than you were just trusting your extra heavy duty hull wasn't making a wake. Sent from my SM-G970U using Tapatalk |
| Author: | huck Finn [ Wed Mar 13, 2019 3:30 pm ] |
Bump it in and out of gear, or trim up. H Finn |
| Author: | dead animal [ Wed Mar 13, 2019 6:02 pm ] |
no wake means no wake. what don't you understand? |
| Author: | Wchauvin [ Wed Mar 13, 2019 6:12 pm ] |
Trim up, that 2 blade has a lot of thrust. If you don't trim up, you will continue to slam into your trailer and or truck |
| Author: | MaXXis85 [ Thu Mar 14, 2019 6:16 am ] |
I've seen it all! Lordy Yes MM's idle fast cause the prop is turning faster per engine rpm than most outboards. Gear ratio... |
| Author: | daddyflea [ Thu Mar 14, 2019 5:52 pm ] |
| Author: | Wchauvin [ Thu Mar 14, 2019 6:10 pm ] |
Put runners and guides on the sides of your trailer and no matter how hard the wind is blowing or the current, your boat won't miss the trailer and you won't ever need reverse when trailering your rig |
| Author: | daddyflea [ Thu Mar 14, 2019 7:03 pm ] |
| Author: | EGood [ Fri Mar 15, 2019 6:08 am ] |
I’ve hit my side bunks pretty hard. Especially in high wind but that’s what side bunks are for. Haven’t broke anything yet. Just don’t back to far in the water. I’ve seen some folks with their bunks fully submerged. My side bunks are fully out of the water so they can help guide the boat. As for you making a wake just trim up like some of the other guys said. Sent from my iPhone using Tapatalk |
| Author: | Wchauvin [ Fri Mar 15, 2019 7:58 am ] |
Looks like you are one of those guys who has 500000 reasons why you can't fix your simple problem. If all of what everyone said can't help you, get used to getting stopped by wardens and slamming into your trailer and truck. I got no other solutions |
| Author: | daddyflea [ Fri Mar 15, 2019 9:12 am ] |
| Author: | BlueShamu [ Fri Mar 15, 2019 9:21 am ] |
| Author: | Russ [ Fri Mar 15, 2019 10:53 am ] |
I thought he was posting because he didn't realize he was making a wake and assumed because he was at idle all was fine. But the extra heavy duty boat.... And I recall at least a couple times you've been here "on the internet" asking questions because something wasn't right. Your attempt to defend your dignity (the last place you would come for help...) is in vain, dear sir. And that may be flawed, too, because there are quite a few guys on this forum (the internet) that I trust and are right far more than many dealers, service people, and even some boat builders. Sent from my SM-G970U using Tapatalk |
| Author: | daddyflea [ Fri Mar 15, 2019 12:04 pm ] |
| Author: | Russ [ Fri Mar 15, 2019 12:33 pm ] |
A wake is a wake. Game warden doesn't care that you were at idle or not. That's a setup/tuning issue. Change the pin location on your frame, and you will be able to trim up farther. You still will be able to trim down for your use of reverse. Sent from my SM-G970U using Tapatalk |
| Author: | Will [ Sun Mar 17, 2019 5:29 pm ] |
I just wasted life reading this shit. Some folks need to stay on the hill... |
| Author: | Wchauvin [ Sun Mar 17, 2019 6:30 pm ] |
| Author: | MaXXis85 [ Mon Mar 18, 2019 5:11 am ] |
No lie just about every mud motor will leave a small wake at idle. Hell they idle about 1250-1300 out of gear and about 850-1000 in gear. they move pretty swift at idle.. You need to bump the clutch to not make a wake in a respectable fashion. |
| Author: | bluesky2012 [ Mon Mar 18, 2019 8:59 am ] |
| Author: | Bigbend [ Mon Mar 18, 2019 9:40 am ] |
Put a bigger rock guard on |
| Author: | daddyflea [ Mon Mar 18, 2019 12:38 pm ] |
| Author: | daddyflea [ Mon Mar 18, 2019 12:44 pm ] |
| Author: | bluesky2012 [ Mon Mar 18, 2019 1:56 pm ] |
| Author: | daddyflea [ Mon Mar 18, 2019 3:56 pm ] |
| Author: | bluesky2012 [ Mon Mar 18, 2019 4:08 pm ] |
| Author: | DmaxHunter [ Mon Mar 18, 2019 6:05 pm ] |
It works, that is my fat ass, I bowfish allot up here. In the daytime a push pole and bow l stack fish. At night you can use motor as blue sky stated. Hell my buddy runs a 5hp kicker and fishes at 5mph or faster and this happens, over 50lb I put first arrow Sent from my SM-N950U using Tapatalk |
| Author: | daddyflea [ Mon Mar 18, 2019 6:27 pm ] |
That is a hell of a lot of Catfish bait there. My Daughter caught three of these the other day on a Spinning Rig. |
| Author: | bluesky2012 [ Mon Mar 18, 2019 6:51 pm ] |
Toss on a suspended jerk bait or a big bright crank and let it rip. Needle nose love them. Sent from my iPhone using Tapatalk Pro |
| Author: | longboman [ Wed Apr 24, 2019 9:16 pm ] |
I don't think I've ever used reverse when loading my boat. If you have to go in hard (pun intended) just pull the trailer out of the water a bit more than normal.....never done that either but I would if I faced your delima. |
| Author: | daddyflea [ Thu Apr 25, 2019 6:29 am ] |
