| New boat question http://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=73808 |
| Author: | Aaronc03 [ Mon May 13, 2019 12:38 pm ] |
| Post subject: | New boat question |
Just picked up a 2016 havoc 556 mst. It’s got a 2014 prodrive 36efi. Just seeing what other people are getting with this setup. I’ve got a few quick fixes on the lower unit I need to make before we can try it out. |
| Author: | Aaronc03 [ Tue May 14, 2019 7:53 pm ] |
| Post subject: | Re: New boat question |
Finally got to run the boat today. Not super impressed to say the lease. Me and my son who is 5 and regardless of what we did the front plowed water. We couldn’t get any lift at all. Motor seemed fine at about 4000-4100 rpm but boat won’t break 20mph. Anyone ever has this issue? Boat is a 1556mst with 36hp prodrive Sent from my iPhone using Tapatalk |
| Author: | bluesky2012 [ Tue May 14, 2019 7:56 pm ] |
Doesn’t sound right. That’s a pretty small and light boat for that engine. Check your prop and make sure both cylinders are firing right. Also, check shaft size too. Feel like that’s been an issue recently where shady sellers are pushing short shafts on tall transoms. Pics and leakdown would likely help get a diagnosis here too. Sent from my iPhone using Tapatalk Pro |
| Author: | Aaronc03 [ Tue May 14, 2019 9:02 pm ] |
here’s a pic of the boat. I can get measurements in the morning to double check. Motor seems to be running strong. Sent from my iPhone using Tapatalk |
| Author: | Aaronc03 [ Tue May 14, 2019 9:04 pm ] |
Also will add the cav plate is off. Just ordered that today from prodrive. Sent from my iPhone using Tapatalk |
| Author: | brycecheramie [ Wed May 15, 2019 7:32 am ] |
Cav Plate wont matter for deep water performance. Whats the bottom look like? Bet its dented up. causing you to plow. |
| Author: | Aaronc03 [ Wed May 15, 2019 8:49 am ] |
Bottom actually doesn’t look that bad really. Nothing major we can see. Sent from my iPhone using Tapatalk |
| Author: | Bigbend [ Wed May 15, 2019 8:54 am ] |
Is this your first SD? Have you experimented with the trim? |
| Author: | Aaronc03 [ Wed May 15, 2019 9:03 am ] |
| Author: | Aaronc03 [ Wed May 15, 2019 9:07 am ] |
I’m wondering if the motor doesn’t need to be dropped some. Sent from my iPhone using Tapatalk |
| Author: | Aaronc03 [ Wed May 15, 2019 7:56 pm ] |
Well got home from work today and went over every inch of the boat. Turns out there are hooks on each of the pods on the hunt deck. Both are pretty bad. I’m a welder by trade and judging by the welds I can tell the joint was fitted like that. There are no scratches not sharp edges nothing. It’s like you dropped each pod on a bowling ball. Called Havoc and they said to find custom shop to repair. I’m going to cut top off of pods repair and then weld back up. Not a huge job just wasn’t to pleased with havocs phone call but it is what it is. Boat runs 20/21mph right now at 4,000 rpm. Prop and motor look and run fine. The hooks are probably about 1/2” to 3/4” deep so I don’t know if this is the whole problem but I’m sure it’s most of my issue. Sent from my iPhone using Tapatalk |
| Author: | Russ [ Wed May 15, 2019 8:03 pm ] |
It doesn't take much. Beat them out, add some plate or flatbar to reinforce those areas well, and roll out. #CFFITR #GhostBoat #Whoneedsphysicsihaveamudmotor |
| Author: | Aaronc03 [ Wed May 15, 2019 8:07 pm ] |
| Author: | Aaronc03 [ Thu May 16, 2019 4:15 pm ] |
Well not so easy. Can’t get to it to beat it out. From the looks I’m fairly sure they hit the hull in reverse. A lot to fix. Only thing I can see if welding sheet on the bottom to cover up the hooks. Sent from my iPhone using Tapatalk |
| Author: | Wchauvin [ Thu May 16, 2019 6:28 pm ] |
That is definitely something affecting your performance bro |
| Author: | cb5331 [ Thu May 16, 2019 7:28 pm ] |
Damn, that thing is fucked! Lol Doesn't help anything being a 15 foot boat, but that transom is mangled. Hope you didn't pay much for this rig. It's an awful match even if the bottom wasn't beat to shit. Sent from my SM-T710 using Tapatalk |
| Author: | bluesky2012 [ Thu May 16, 2019 7:46 pm ] |
I guess that’s fixable, but honestly, I’d just sell the hull to someone wanting to put an outboard on it, and get a new hull. Also, they must have been running on plane in reverse to have done that... Sent from my iPhone using Tapatalk Pro |
| Author: | Aaronc03 [ Thu May 16, 2019 7:46 pm ] |
| Author: | bluesky2012 [ Thu May 16, 2019 7:50 pm ] |
| Author: | Aaronc03 [ Thu May 16, 2019 7:51 pm ] |
| Author: | bluesky2012 [ Thu May 16, 2019 7:56 pm ] |
| Author: | Aaronc03 [ Thu May 16, 2019 8:15 pm ] |
| Author: | cb5331 [ Thu May 16, 2019 10:09 pm ] |
Something built for a mudmotor for starters. Any of the builders will put a pointed bow on for you. Prodrive is a good place to look. Their boats work well with their motors. There's also a slough of custom builders who can do just about anything you want, within reason. Sent from my SM-T710 using Tapatalk |
| Author: | Aaronc03 [ Fri May 17, 2019 12:13 pm ] |
Well just spoke to Tyler at Timber Creek Boats. New hull on the way. Went with one of their timber runners. Sent from my iPhone using Tapatalk |
| Author: | Will [ Fri May 17, 2019 7:08 pm ] |
Cha ching!! |
| Author: | DuckHunterF250 [ Fri May 17, 2019 9:02 pm ] |
are these the same boats they had videos of jumping other boats and dragging em on concrete and said they were the toughest boats built? or was that another brand? |
| Author: | Russ [ Fri May 17, 2019 9:08 pm ] |
I do seem to remember a video or 2 of such shenanigans. This is at the back, though. They dont need any proper bracing back there lol #CFFITR #GhostBoat #Whoneedsphysicsihaveamudmotor |
| Author: | Aaronc03 [ Sat May 18, 2019 5:25 am ] |
Well I can personally say that’s bs. Also if you call them they will tell you not their problem take it to a custom shop to be fixed. Sent from my iPhone using Tapatalk |
| Author: | bluesky2012 [ Sat May 18, 2019 5:51 am ] |
| Author: | JIMMY W [ Sat May 18, 2019 5:43 pm ] |
It’s a poodrive sell it and get a GatorTail |
| Author: | Wchauvin [ Sat May 18, 2019 5:56 pm ] |
| Author: | Aaronc03 [ Sat May 18, 2019 6:02 pm ] |
Well we welding on some .125 plate over the hooks today and we are back to 29mph with lift. Ordered a new hull but at least have this one back to running okay. Sent from my iPhone using Tapatalk |
| Author: | Will [ Sat May 18, 2019 7:00 pm ] |
| Author: | Wchauvin [ Sat May 18, 2019 7:15 pm ] |
29 is not bad at all. Sounds like y’all definitely make some good corrections bro |
| Author: | dead animal [ Sat May 18, 2019 7:52 pm ] |
sounds like u got if corrected. if you like the boat, keep it !!!! good luck! |
| Author: | WhoDat88 [ Wed May 22, 2019 11:20 pm ] |
29 is pretty darn good for a slow hull like that. That hook you had was killing your performance |
