I need a good welder
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=7460
Author:  BradS [ Sat Jan 30, 2010 11:05 pm ]
Post subject:  I need a good welder
:cry:
Author:  shallow water master [ Sun Jan 31, 2010 8:33 am ]
Post subject:  Re: I need a good welder
hay brads talk to blaze he is a welder by trade he should be able to fix u right up.
if not i have a friend that i can send u to that does it to
Author:  JIMMY W [ Sun Jan 31, 2010 8:38 am ]
That is not good!!Good way to lose a rig :o
Author:  BradS [ Sun Jan 31, 2010 11:19 am ]
Well I saw it when I got the boat on the trailer so I put a strap on it
Author:  TXSHOCKWAVE [ Sun Jan 31, 2010 1:37 pm ]
make sure they weld a doubler plate to the boat first them reattach the bow eye. The doubler plate will help spread the load out so that doesn't happen again.
Author:  Tenpoint [ Sun Jan 31, 2010 2:03 pm ]
Author:  BradS [ Sun Jan 31, 2010 2:53 pm ]
Author:  Tenpoint [ Sun Jan 31, 2010 3:35 pm ]
Author:  UNCLE-J [ Sun Jan 31, 2010 4:34 pm ]
Brad,
If you are around, bring it to me. I will fix it for Free. Also, I have some plate over here to make your doubler plate.
With Love,
Uncle-J
Author:  curcio13085 [ Sun Jan 31, 2010 7:36 pm ]
mine did same thing but i have a double plate already so what should i do now?
Author:  willett [ Mon Feb 01, 2010 9:18 am ]
Author:  POKER1 [ Mon Feb 01, 2010 12:06 pm ]
How are you putting that kind of pressure on the eye? Winching the heavy hull up or is it happening during travel? Run that thing up on the trailer. I don't have to winch mine very often.
Author:  UNCLE-J [ Mon Feb 01, 2010 1:08 pm ]
I think I seen Brad pushing some skimmers with his boat. He pullls off of the bow. All that PD power can put a strain on the frames thus pulling the eye on the bow of the boat. I hope this clears everything up.
With Love,
Uncle-J
Author:  BradS [ Mon Feb 01, 2010 3:04 pm ]
Author:  bbeakl1 [ Mon Feb 01, 2010 4:10 pm ]
Try putting an extra strap around the front of the boat and tongue of the trailer when traveling. I had the same thing happened, pretty sure its from the boat bouncing around while driving and you keep stressing the welds on the hook. Something is gunna give sooner or later.
Author:  BradS [ Mon Feb 01, 2010 11:46 pm ]
Author:  POKER1 [ Tue Feb 02, 2010 12:49 am ]
Author:  BradS [ Tue Feb 02, 2010 6:19 am ]
Author:  stumpgrinder [ Tue Feb 02, 2010 7:36 am ]
Author:  caddobrook [ Tue Feb 02, 2010 10:08 am ]
X2 on the earlier comment on boat bouncing on the trailer.
Problem is a lot of the flat front or even semi-v boats don't really fit on the trailer stops/roller by the winch very well.
Mine did it on two boats. Both boats I went to a double plate and replaced roller with a piece of carpeted 2x6 to give the flat part of the boat a solid piece to rest on.
Like stump said the strap is just there to keep the boat from rolling off and assist in getting it on the trailer. The trailer needs to be fit to let the boat ride secure...
Author:  UNCLE-J [ Tue Feb 02, 2010 11:05 am ]
Brad my boy...
Give me a call tomorrow before you come. Uncle-J will take care of you.
Author:  craig [ Tue Feb 02, 2010 9:17 pm ]
Brad................next time you cranc up on it try and not put all your weight into it. :mrgreen:
Author:  UNCLE-J [ Mon Feb 08, 2010 7:31 pm ]
The reason why it ripped, is due to it being put on backwards. The way it was put on caused a hinge like presure on the front. If it would have been put on right, it would have never cracked.
I put it on the correct way.
Love, Uncle J
Author:  BradS [ Wed Feb 10, 2010 6:09 am ]
Thanks Uncle J
Got her welded up nicely on a plate.
