| Gator Trax hull pitting http://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=74772 |
| Author: | Michigandkhunter [ Sat Dec 07, 2019 10:24 pm ] |
| Post subject: | Gator Trax hull pitting |
2011 Gator Trax Marsh Series 1750 w/ hunt deck. Found pitting all over on bottom of the hull, one area leaking. Freshwater use only, no onboard charging system besides a system made by original owner that allows battery to charge off towing vehicle. Treated trailer bunks with heavy duty plastic covers in excellent condition. I’m second owner and bought boat 2 months ago. I know the first owner well and he took immaculate care of this boat, thus, I never inspected the hull when I purchased; my mistake. The boat was gently used in my opinion by 1st owner. Heck, the 2011 black death had 34 hours on it when I purchased. The boat was kept in heated storage its entire life. I am having a hard time understanding how a hull from a company I’ve heard so much about can have this pitting issue after 8 years of gentle freshwater use. Cheap overseas aluminum? WTF! Any one familiar with this? Input please and thanks. If this has been discussed somewhere else please help me out, I searched and didn’t find much. |
| Author: | DmaxHunter [ Mon Dec 09, 2019 6:01 am ] |
| Post subject: | Re: Gator Trax hull pitting |
call them, they have a lifetime warranty on their hulls. Atleast see what they will do Sent from my SM-G973U using Tapatalk |
| Author: | Michigandkhunter [ Mon Dec 09, 2019 6:12 am ] |
[quote="DmaxHunter"]call them, they have a lifetime warranty on their hulls. Atleast see what they will do Sent from my SM-G973U using Tapatalk That had been done already. Was told warranty for marsh series hull is 1 year for the 1st owner. They suggested gator glide. Looks like this will be my first and last Gator Trax. |
| Author: | Russ [ Mon Dec 09, 2019 6:42 am ] |
Gator trax suggested gator glide to fix pitting and a leak on a hull they built? Wow. Times must be hard down there. #CFFITR #GhostBoat #Whoneedsphysicsihaveamudmotor |
| Author: | Frog [ Mon Dec 09, 2019 9:06 am ] |
Could be on-board electrolysis from the charging system. Boat needs to be properly grounded. Is the pitting where it sets on the bunks or all over? |
| Author: | Frog [ Mon Dec 09, 2019 9:19 am ] |
If you're going to use the GatorGlide to insulate the bottom of the boat you need to treat it first. I would sand it down best you can and then maybe use a wire wheel. "A stainless wire wheel "you do not want to use a carbide wire wheel you'll create a battery on the bottom of your boat. clean the pits out the best you can and then use vinegar and water solution about 30 to 40% vinegar and the rest water, that will eat some of that corrosion out of the pits that you can't reach with the wheel. I would wash it a couple of times and then clean it good soap and water, let it dry then wipe with acetone. Then I would use the gatorbase and then G2. I don't like the plastic bunk covers or pressure-treated against aluminum that also causes pitting and the plastic bunk covers create a lot of wear. I just put down to Spruce 2 by 8 on my air boat trailer after 8 years with gatorglide on the old bunks. call me anytime |
| Author: | Michigandkhunter [ Mon Dec 09, 2019 9:46 am ] |
| Author: | Michigandkhunter [ Mon Dec 09, 2019 9:52 am ] |
| Author: | Frog [ Mon Dec 09, 2019 10:40 am ] |
| Author: | Michigandkhunter [ Mon Dec 09, 2019 11:17 am ] |
| Author: | Frog [ Mon Dec 09, 2019 2:11 pm ] |
| Author: | Michigandkhunter [ Mon Dec 09, 2019 9:26 pm ] |
So if my google’ing is correct, installing a sacrificial anode made of magnesium should help. If this is true, anyone know how to determine how big and where the anode should be installed on a GT hull? Pitfalls of installing an anode? Does it work? Who has em’? |
| Author: | Russ [ Mon Dec 09, 2019 10:10 pm ] |
I would solve the underlying issue before adding that. Pitting happens, but it's a rare thing in a freshwater only boat, so something's going on worth figuring out. Then you can add the anode for peace of mind. #CFFITR #GhostBoat #Whoneedsphysicsihaveamudmotor |
| Author: | Michigandkhunter [ Tue Dec 17, 2019 4:15 pm ] |
| Author: | Russ [ Tue Dec 17, 2019 7:01 pm ] |
Battery hooked to motor, black to negative, red to positive. Dont ground shit to the boat. At all. #CFFITR #GhostBoat #Whoneedsphysicsihaveamudmotor |
| Author: | Will [ Tue Dec 17, 2019 7:16 pm ] |
Yep, electrolysis don't ground to the boat, fresh water, salt water , bunks, none of that matters. Don't transfer through the hull itself. |
| Author: | MaXXis85 [ Wed Dec 18, 2019 9:32 am ] |
BUT, your motor bolts to the boat. which the motor is grounded.... HMMM |
| Author: | cb5331 [ Wed Dec 18, 2019 2:46 pm ] |
| Author: | Will [ Thu Dec 19, 2019 6:33 am ] |
| Author: | Will [ Thu Dec 19, 2019 6:43 am ] |
I used the wrong term, not electrolysis, electrolytic corrosion is what I was thinking. "Stray current" passing through the hull. Could be a chaffed wire somewhere or bad ground or neutral allowing the hull absorb and transfer voltage. Sent from my Pixel 2 using Tapatalk |
