| Water logged foam http://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=75677 |
| Author: | Slick1976 [ Sat May 22, 2021 4:29 pm ] |
| Post subject: | Water logged foam |
Do the newer excel boats have the same problems with the foam becomkngnwater logged. Looked at a nice used excel and wondered if this was still a thing or if they solved it |
| Author: | Bigbend [ Tue May 25, 2021 11:13 am ] |
| Post subject: | Re: Water logged foam |
All foam will eventually hold water, closed cell or otherwise. May not be an issue for 10 years, but could be quicker than that if the boat sat uncovered in the elements with water sitting in it. |
| Author: | Wchauvin [ Tue May 25, 2021 12:18 pm ] |
Just get a boat without foam and be done with it bro |
| Author: | Gigafowl [ Tue May 25, 2021 1:25 pm ] |
What size and model of Excel are you looking at ??? What motor are you thinking of using on it ??? If the price is right - use the coins you save to fix it up the way you want it to be... Until then run the heck out of it... |
| Author: | kib876 [ Tue May 25, 2021 8:35 pm ] |
All foam will eventually hold water if not properly cared for, with biggest factor being how it is stored....in shop, under a cover, or left wide open in the rain time and time again, has the plug been left in allowing water to stand in the boat, etc etc etc |
| Author: | Slick1976 [ Thu May 27, 2021 1:38 pm ] |
Thanks for the responses guys. Unfortunately there aren’t a lot of custom builders up in the north woods. |
