It is currently Thu Feb 05, 2026 11:47 am
Reply to topic  [ 12 posts ]
 Polling platform is too low
Post Polling platform is too low
I have a 1644 go devil boat and have a go devil surface drive on it. My problem is that there is not enough clearance between the top of the motor and the bottom of the polling platform. Is there a way that I can raise the polling platform up using some type of spacer or anything?
1644 Go-Devil
2008 23 GDSD
Sat Apr 10, 2010 10:45 pm
Post Re: Polling platform is too low
Post up some pics so we can get a look at it.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun Apr 11, 2010 3:50 am
Ok. I'll take some today and put 'em up.
1644 Go-Devil
2008 23 GDSD
Sun Apr 11, 2010 7:24 am
MMT Moderator
You can probably cut some sleeves and drill some holes and add a 4" extension piece off each leg with a bolt or quick disconnect that fits in... Not sure if you've used tube or flat bar.. Post some pics. TXSHOCKWAVE is a good person to ask he just did my platform... A lot of others will chime in that work with aluminum once you post some pics.
GTB 1860 w/ 2019 GTR40XD-HO
Sun Apr 11, 2010 8:32 am
Sounds like an older platform made for longtail....
Newer ones are 10 to 12 inches taller - it should be easy
to have a shop extend and re-bend the uprights....
Eat - Sleep - Hunt ! ! !
Sun Apr 11, 2010 8:53 am
dude just add some washers to the bottom of the platform and use long selftapping screw. Thats what we did on a buddy of mine and it worked great.
WC 1848 Bateau w/ 36 PD FPR
Sun Apr 11, 2010 9:59 am
Or you could just sell that one and buy the right one
23 hp gdlt pushin the 14ft NoWeld "aka" the black pearl
35 hp gdsd pushin a 16/60 go devil boat
Sun Apr 11, 2010 11:04 am
Without seein it, I was kinda thinkin along the same lines as Shafer. My lil bro just took a 3" body lift off a jeep and had the blocks just layin around. If they'll work, let me know and I'll try to get em before he chunks em.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun Apr 11, 2010 2:35 pm
Giga hit it on the head there. I've got the non-surface drive boat with a surface drive motor. So are you saying cut the legs near the bottom, weld in some 10 or 12 inche extensions, then rebend so that the everything mounts up right again?
1644 Go-Devil
2008 23 GDSD
Sun Apr 11, 2010 8:28 pm
Not sure about the 23 GDSD - but on a 35 GDSD you need at least
10 to 12 inches more clearance than the LT style platform provides....
I would cut away the bottom mounts as low as possible - cause the
angles will change for the uprights - grind it smooth and reweld the
10 to 12 inch extensions back to it with the correct upright angle
after the re-bend just below the platform which will be required to
get the correct width....
The 16x44 works fine with a SD - and the platform protects both
you and the motor from tree limbs and obstacles - also nice to lean
against or hang on to when driving.... It would be worth the effort
to modify and keep it....
Take a look at what Robn's done to his ole hull.... Sweet now....
Look close under the platform at his jam box too...
viewtopic.php?f=7&t=8992
Sun Apr 11, 2010 8:57 pm
X2 Backwaterballer. Too much to deal with. Sell it and get one that works.
My Chessie is the Queen of the Marsh!!!!
"The democracy will cease to exist when you take away from those who were willing to work
and give to those who would not." Thomas Jefferson-1802
"When the Government fears the people that is liberty
When the people fear the government that is tyranny"- Thomas Jefferson
Sun Apr 11, 2010 9:10 pm
I'll but the old one for 150
Sun Apr 11, 2010 9:13 pm
