It is currently Thu Oct 01, 2026 2:42 pm
Reply to topic  [ 9 posts ]
 Installing Hydroturf
Post Installing Hydroturf
I just ordered some hydroturf and under mat for my bowfishing boat. Do y'all have any tips or hints that will help me from royaly screwing up this $300 investment during installation? Thanks
1854 Sportsman's Fab
2046 Uncle-J Skiff
35 GTR
Sun Apr 25, 2010 9:53 pm
Post Re: Installing Hydroturf
Take your time. And remember that it will stretch some as you lay it down. At least a 1/4".
18x48 Charles Leonard / 36PD
Sun Apr 25, 2010 9:57 pm
Sun Apr 25, 2010 9:58 pm
Not sure which one you purchased the 3M peel and stick or the kind you have to glue down. If you got the kind you have to glue yourself and stick down. glue both surfaces well and let them dry completely. Cut yourself a piece of plastic long enough to cover the working area and after your working area is completely dry lay the plastic over it and then your sheet of hydroturf. When you get the turf lined up where you want it slowly pull out the plastic and press down on the turf. Again like stated this stuff will shrink make it fit very tight so that it will shrink up and not leave a wide gap.
Post some pictures when you are finished
1754 GT EXTREME 37EFI
Sun Apr 25, 2010 10:33 pm
Not sure what HT you used that shrank. Every piece I layed expanded. If you use the weldwood glue as suggested you can roll it up and unroll as you Kay it down. The glue only sticks to other objects that have glue on it.
Sun Apr 25, 2010 10:51 pm
As poker 1 said make sure you get some help.
My Chessie is the Queen of the Marsh!!!!
"The democracy will cease to exist when you take away from those who were willing to work
and give to those who would not." Thomas Jefferson-1802
"When the Government fears the people that is liberty
When the people fear the government that is tyranny"- Thomas Jefferson
Mon Apr 26, 2010 6:07 am
don't put the underpad all the way to the edge of turf stop it atleast 1" so that the turf overlaps and glues down to the deck this will help from it peeling up
use dollrods in between so you can keep sheet from stickin until your you got it where you want it the glue only sticks to itself this way you can handle the sheets better. a install tip from camo-toad.com any other question call Richard 225-802-8579 an they could have saved you on $300
Motorless 18X54 Custom
Mon Apr 26, 2010 6:25 am
Like mentioned before. Take your time, measure twice cut once, keep in mind this will expand a little. And if you are usin dda kind dat needs to be glued down, I recommend gluin it down wit contact cement. But becareful because once you put it down you ain't gettin it back. You can stick a cat's ass to a door knob wit dat stuff.
Mon Apr 26, 2010 11:49 am
Mon Apr 26, 2010 3:08 pm
