It is currently Mon Sep 22, 2025 4:12 am
Reply to topic  [ 2 posts ]
 Too Much Prop?
Post Too Much Prop?
I'm running a Hopkins 12x13 with heavy tip curl on a Stage 1 PD36 2054. Speed is not bad at 28 deep water empty and 25 with a load. This is at around 3700 RPMs. My stock prop would run around 4500 rpms with not much difference in speeds. The prop was built for a stage 2 motor I think.
Obviously the lower rpms is a good thing, but I'd like to get the rpms up to around 4k. Should I just run it until it wears down a little or is is better to have a prop shop take it down a little?
WC Custom 1854
Tue Apr 27, 2010 6:33 am
Post Re: Too Much Prop?
Make one high speed pass across the sand. This should bring the RPM'S up. I know it always brought mine up.
Tue Apr 27, 2010 6:40 am
