It is currently Wed Sep 24, 2025 12:04 am
Reply to topic  [ 31 posts ]
 carnage........
Post carnage........
Well while in the process of killing ducks and catching sacalait my lower unit decided to split like brothers in the hood when da cops roll up. Anyways I was running back up the calumet when I notice I have gear oil spewing out from my shaft beneath my clutch. And upon further inspection this was found......
suspect is the upper bearing..and it was a new style lower unit....I guess im just a clear water pirate :lol:
27 Contender twin 200's
for sale
Wed Jan 05, 2011 9:50 am
Post Re: carnage........
guess these were the pics Bubba posted on FB
Sometimes it's best to just keep your fingers quiet...
Thu Jan 06, 2011 4:23 pm
yea thats the ones I posted
I gave up mud motors
Thu Jan 06, 2011 7:11 pm
Sorry to see that their hunter!! Those gears and lower unit are pretty costly!!
17x48 extreme stage 2 GTR
Thu Jan 06, 2011 7:27 pm
for sale
Fri Jan 07, 2011 8:35 am
Fri Jan 07, 2011 9:36 am
Hell, its all costly unless you get it free.
18x48 Charles Leonard / 36PD
Fri Jan 07, 2011 12:38 pm
Sat Jan 08, 2011 8:05 pm
Oh thats right we do have a life time warranty, well shucks i forgot about that! :P
Sat Jan 08, 2011 8:10 pm
Pro Drives are nice but it seems like there are less things to go wrong with the drive systems on the other manufacturers than on a Pro Drive. Maybe I'm wrong but it sure does seem easier to replace a gear, belt, and some seals than the lower unit on a pro drive.
"We Are Products Of Our Decisions"
Tue Jan 11, 2011 9:57 am
Wed Jan 12, 2011 12:00 am
you have to pay to play thats all. I will say it did get me back 5 miles from when I discovered the minature oil well.
its still a hell of alot cheaper than running airboats
for sale
Tue Jan 18, 2011 3:45 pm
Tue Jan 18, 2011 6:00 pm
Tue Jan 18, 2011 6:24 pm
Tue Jan 18, 2011 6:41 pm
Wed Jan 19, 2011 12:10 am
Is that the new lower unit that they started installing around September 2010?
18'x54"CC Hanko/ 36PD
Tue Jan 25, 2011 6:15 pm
I picked mine up in 2009 and it has the new style lower unit........
Thu Jan 27, 2011 1:43 am
They came out in 2008.
Thu Jan 27, 2011 11:24 am
There is a "newer" lower unit that is being used now, as of August/September 2010. The gearcase is now sealed right at the prop shaft. The prop shaft housing is now filled with grease to fix the problem of water getting in through bad seals at the prop.
Thu Jan 27, 2011 5:42 pm
Same one Poker is talking about as far as I know...We def got one well before August 2010.
*edit* Well, maybe you are talking about something different. I didn't thoroughly read that post the first time. So there is a grease zerk on the bottom now too, not just at the top or what?
Thu Jan 27, 2011 5:49 pm
I am sure that must be a free upgrade right?
Gator Trax 1854 ran over by drunk driver!! ( boat less)
Thu Jan 27, 2011 5:51 pm
Thu Jan 27, 2011 5:53 pm
yea, I guess they call that product improvement, but when it's a mb it's "they fuked me". ;)
Thu Jan 27, 2011 6:03 pm
Thu Jan 27, 2011 6:08 pm
2 please ;) It don't matter 8 inches of ice, the boat won't hit the water till mushroom season. by then, I'll have a merc retrofitted in there and won't whine about it ;)
Thu Jan 27, 2011 6:12 pm
Thu Jan 27, 2011 6:15 pm
I'm not, but I'm gona get one off an outboard and put on, cuz it WILL go out. I looked at a cmc, but gt uses them and it don't seem to be worth a fuk either. So go with tried and true merc or I will just get a hyd cyl and pump and do it right. I do understand that putting 1/5 of the price of the mm for the trim is alot, so they ALL have to scrimp someware.
Thu Jan 27, 2011 6:31 pm
just go mine new pd same lower new style but kp has added a grease pocket with a fitting, to have a grease seal in front off the gear oil
driving a gd in ur lake
and i aprove this message
Thu Jan 27, 2011 9:03 pm
Meterman3 may have explained it a little better. Maybe not.
Fri Jan 28, 2011 12:47 pm
If my belt brakes I'm smart enough to cut my dock rope and limp n
Sat Mar 19, 2011 9:21 pm
