It is currently Wed Sep 24, 2025 12:48 am
Reply to topic  [ 19 posts ]
 How to change prop on Pro Drive??
Post How to change prop on Pro Drive??
I got my new prop today and can't seem to get the old one off. It almost seems like it is seized up on the shaft. Some pointers or directions on how to do it properly would be great. Thank, Chase.
"Drop the Hammer"
Excel 1651 F4 with a Mud Buddy HD7000
Excel 1860 F4 with a Mud Buddy HD5500
Thu Apr 07, 2011 6:54 pm
Post Re: How to change prop on Pro Drive??
What all are you using and what have you done so far?
Thu Apr 07, 2011 6:55 pm
took the nut off and tried to hit the end of the prop with a dead blow hammer to get it loose.
"Drop the Hammer"
Thu Apr 07, 2011 6:57 pm
Well that was retarded.
Do you not have the manual that came with your motor?
Thu Apr 07, 2011 6:58 pm
go to thier web site down load pf file you take nut off did u put the 1/2 bolt in the hole to freeze the shaft
driving a gd in ur lake
and i aprove this message
Thu Apr 07, 2011 6:59 pm
No. I do not. It seemed logical to me. I didn't do it but 2 or 3 times and it occurred to me that wasn't right. It would be great if I could get some pointers.
"Drop the Hammer"
Thu Apr 07, 2011 7:00 pm
owen what is a wiggles ?
Did you do anything to keep the shaft from spinning?
Thu Apr 07, 2011 7:02 pm
Got it now. Thanks meterman.
"Drop the Hammer"
Thu Apr 07, 2011 7:03 pm
http://www.prodriveoutboards.com/images ... nual08.pdf
Thu Apr 07, 2011 7:04 pm
Thu Apr 07, 2011 7:05 pm
Buy the prop wrench and machined pin to lock the shaft up from PD. Its a great investment and will make your life much easier.
18x48 Charles Leonard / 36PD
Thu Apr 07, 2011 10:08 pm
X2
a couple little tips when your removing the prop trim the motor down a little then look at the front the prop ( toward the bow) turn the prop until the slot in the prop bushing is on top the shaft, either pour a little 90w or shoot some WD-40 in the slot this will lube the bushing as it turns on the prop shaft.
When your reinstalling the prop and after you coat the threads with never sieze run a line of 90W oil across the top the threads, it will come off twice as easy the next time round.
Thu Apr 07, 2011 10:38 pm
Alright guys thanks. My pop is a machinist so he can make the tools so I won't have to spend that money.
"Drop the Hammer"
Thu Apr 07, 2011 10:42 pm
Thu Apr 07, 2011 10:52 pm
"Drop the Hammer"
Thu Apr 07, 2011 10:57 pm
Ask him to learn ya
Mon Apr 11, 2011 2:53 pm
Oh I'm watchin and learnin all I can!!
"Drop the Hammer"
Mon Apr 11, 2011 8:27 pm
