It is currently Wed Sep 24, 2025 3:42 am
Reply to topic  [ 12 posts ]
 Grease ozzing from the drive shaft ??
Post Grease ozzing from the drive shaft ??
I have a little bit of what looks/feels like greese coming out from the drive shaft in the pictures below and was wondering if this is normal or a problem ??
it is from the join farthest from the prop or closeest to the belt drive.
Thanks,
Tue May 24, 2011 10:44 am
Post Re: Grease ozzing from the drive shaft ??
"DagGum It"
Thats what I calls them photos .....
Tue May 24, 2011 2:00 pm
Mine has what looks like transmission fluid leaking out of the grease zert. Trying to figure out what it is.
17x50hd gator trax 45mag mb
Tue May 24, 2011 7:00 pm
Neff, yours is normal, it's just the thinner grease oozing from the heat.
ODG, your housing is cracked.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue May 24, 2011 7:12 pm
Makes since. Thanks camo.
Tue May 24, 2011 7:47 pm
Can that be welded or does the whole thing need to be replaced?
Wed May 25, 2011 7:06 pm
He also posted it on MB, & got more detailed answers. According to Andy (BoatDr) it has to be replaced. I initially thought the same about having it welded, until he said the only 2 options both included replacing it. It's actually 2 pieces pressed together & apparently he must've tried to repair one before, rather than replace it & it was a no-go.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Wed May 25, 2011 7:14 pm
Gator Trax 1854 ran over by drunk driver!! ( boat less)
Thu May 26, 2011 5:31 am
Thu May 26, 2011 7:13 am
Where are you located and what do you have? Im trying to decide on getting a longer shaft for my 35, if i do I will be looking to get rid of my current one if you are interested and looking.
Bayou Gun Runner
Sat May 28, 2011 5:48 pm
18x52 Widow Maker Hull being pushed by a HD 5500 BAMF...
Sat May 28, 2011 7:26 pm
I pulled the drain plug on the shaft and released the excess grease which helped allot. I'm going to run it for a while and see if it keeps up. Team Camo was right and the thread on the MB forum is much more detailed. I hope this all works out without any substantial change required. I use JB Weld on everything !!
C-u on the water !!
Tue May 31, 2011 11:18 am
