It is currently Tue Sep 23, 2025 8:52 pm
Reply to topic  [ 11 posts ]
 Pitch which way????
Post Pitch which way????
Ok I have a 23GTR and I have a nomad prop but I need one to run the federal reserves down in Texas. I called baumans in houston and they said they could do whatever I needed done. I am going the make the prop 9 1/4 diameter but not sure what pitch it needs to be. Its a 35hp grr prop so its a 11 pitch right now. What would be the best pitch so im not all up on my rev limiter. Not much mud running either so that's not much or a factor.
Mon Aug 08, 2011 1:48 pm
10 pitch and cup it to get it tuned!! Try about a 1/2" of cup
17x48 extreme stage 2 GTR
Mon Aug 08, 2011 1:51 pm
Post Re: Pitch which way????
10 understandable. But a 1/2 inch of cup f-me really? I was projecting 9 1/2 pitch with factory style cup being it gonna have be copied from a new prop just a 91/2 diameter.
Mon Aug 08, 2011 2:01 pm
MMT Moderator
Tell Louis to call me...
These props have a progessive pitch.
GTB 1860 w/ 2019 GTR40XD-HO
Mon Aug 08, 2011 2:03 pm
MMT Moderator
Did you talk to Louis or his brother? His brother works on all the props. Their Dad Louis Sr. ran the shop & supplied my families barge business for years.
They do good work. But fine tuning a prop is very difficult. They have the stock 35 GTR prop they can work from. I supplied it to them.
Mon Aug 08, 2011 2:08 pm
Ok Coe but I told them that you brought a factory new prop in there to get the dimensions off of that one. Did they not do that Coe? I did mentioned your name when asking if that could do this!
Mon Aug 08, 2011 2:10 pm
Ok that WEA!
Mon Aug 08, 2011 2:12 pm
MMT Moderator
Dude just call me I have tried posting a reply 3x now & its a PITA when my text gets deleted because of stupid max user errors!
Mon Aug 08, 2011 2:18 pm
Posted that the same time you posted your second reply. Didn't see it.
Mon Aug 08, 2011 2:21 pm
If its the same federal marshes I hunt in Southeast Texas you cant run a prop over 9 inches in diameter.Are you having the diameter cut down also?
Tue Aug 09, 2011 6:25 pm
Reread my first post! thats what i'm doing is cutting it to a 9 1/4 then repitching it. talked to hoyt at gator-tail and he sad if anything i need to go up in pitch from a 10 to a 11 or 12. but he said to run it first with a hunt load to see how it did cut down to 9 1/4 diameter. cause he said the 23gtr;s tend to bog with a hunt load and with the smaller prop i might like the fast rev i get with the load.
Wed Aug 10, 2011 8:02 am
