It is currently Wed Sep 24, 2025 12:20 am
[ 7 posts ] |
muddyriver
 new versus old
How does one know if they have the older style lower unit or the new style lower unit. I bought mine new between 2005-2007. Can't remember specifically until I get home, but thought maybe someone could give me some early insight.
If I need to change the tower housing sleeves is it best to update the lower unit then? What's the problem with the old unit?
Wed Aug 24, 2011 2:18 pm |
BASSMASTER
Joined: Thu Jul 22, 2010 12:55 pm Posts: 1091 Location: TX
 Re: new versus old
umm what brand?
_________________ Gave up hunting ducks and started underwater basket weaving!
Wed Aug 24, 2011 2:30 pm |
cb5331
 Re: new versus old
Assuming you are talking about a pd...
The older one's were more likely to leak. You don't have to change it unless your having a problem. If your's has never been replaced, you have the old style, but if you aren't having any issues, there is no reason to replace it.
The newer ones are filled with grease on the bottom and top. Basically making it where water can't get in the gear housing from either direction. The one they released a couple years prior to that had grease in the top. The one you are running now is just full of fluid, no grease.
Wed Aug 24, 2011 4:22 pm |
Tenpoint
Joined: Thu Aug 27, 2009 5:22 pm Posts: 2029 Location: Patterson LA
 Re: new versus old
_________________ 19x48 Rink/Aucoin Bateau w/35 GTR 20x60 Home-made skiff w/200 Merc
Wed Aug 24, 2011 6:05 pm |
pooldoo73
Joined: Tue Jan 25, 2011 5:47 pm Posts: 886 Location: Plaquemine
 Re: new versus old
The newest LU is from around august 2010 as far as I know, mite b a newer one than that. If your prop shaft seals aren't giving u continuous trouble I wouldn't bother with it.
_________________ 18'x54"CC Hanko/ 36PD
Wed Aug 24, 2011 6:07 pm |
POKER1
Joined: Tue Jan 13, 2009 8:02 pm Posts: 6243 Location: Bossier City
 Re: new versus old
Your not going to gain anything by swaping it out aside from fixing a leaking seal.
_________________ 18x48 Charles Leonard / 36PD
Wed Aug 24, 2011 6:31 pm |
willett
Joined: Wed Jan 14, 2009 10:22 am Posts: 1764 Location: Tyler, TX
 new versus old
The first change came in 2008 and is when they started using 6 bolts to mount it instead of the original 4 and changed the way to keep water out. Also was when they started putting a larger gear box on it for the opportunity to put different gears in for different applications in the future.
Not sure what's different now.
_________________ Pete Willett WC Custom Boats - Tyler, TX http://www.wccustomboats.com
WC Custom 2048 3/16 Bottom Center Console with 35 PD EFI GTR WC Custom 1840 Hybrid 3/16 Bottom with 37 EFI BOSS
Wed Aug 24, 2011 6:59 pm |
[ 7 posts ] |
