It is currently Wed Sep 24, 2025 12:20 am
Reply to topic  [ 15 posts ]
 HELLLLLLP!!!!!!!!!!
Post HELLLLLLP!!!!!!!!!!
:shock: I cannot get my freakin PROP off my 23 HP GD surface drive. I don't have a prop wrench that fits it, any secrets or really good lubes in getting these SOBs off? Thanks!
[color=#00BF00]18 x 44 Gator Trax Guide Edition pushed by 35 HD Mud Buddy
Thu Sep 08, 2011 6:46 pm
They say Giga has some good GD lube. But I don't know for sure.
If the Steel aint Flying the Birds aint Dying....
Uncle J 1948 holding a LT
Uncle J 1848 w/?
Thu Sep 08, 2011 7:28 pm
Post Re: HELLLLLLP!!!!!!!!!!
Giga?
Thu Sep 08, 2011 7:30 pm
18x48 Charles Leonard / 36PD
I seriously need to get this sucker off tomorrow before Saturday WOODY SEASON!
Thu Sep 08, 2011 7:33 pm
WD40 a block of wood and a dead blow hammer. Aw and make sure your beating the right way.
Uncle J 1848 w/?
Thu Sep 08, 2011 7:49 pm
You need to heat the hub of the prop with a torch, until it glows. It will torque off easily then.
Or you can hold the set nut with a crescent wrench and hit the prop blade with a sledge hammer. I use a cinder block to set the skeg on top of so there is little movement of the shaft. Destroys the prop, but sometimes gets it off.
Thu Sep 08, 2011 9:02 pm
Thu Sep 08, 2011 9:05 pm
36hp Pro-Drive with EVT exhaust pushin a 17x42 custom skiff
Thu Sep 08, 2011 9:32 pm
is it threaded? they sell prop wrenches at home depot...
2"x.25" flat bar with the appropriate size hole should work.
spray the nut down with a penetrating lubricant like PB break first.
23 MB mini w/ IM heads, BPS rockers/rods and gutted exhaust on a rivited 1648 crestliner.
Thu Sep 08, 2011 9:50 pm
Fri Sep 09, 2011 5:59 am
Wow !! It's taken less than minute to take one off and put back on!! Just saying !!
17x48 extreme stage 2 GTR
Fri Sep 09, 2011 7:56 am
Fri Sep 09, 2011 11:46 am
Thanks Guys for all the ideas. A little PB Blaster and an Eastwing finally did the trick :D
Wed Sep 14, 2011 5:41 am
It's a good feeling when it finally spins.
Wed Sep 14, 2011 8:08 pm
