It is currently Wed Sep 24, 2025 12:09 am
Reply to topic  [ 10 posts ]
 Lower unit oil replacement problem
Post Lower unit oil replacement problem
Pulled top Allen plug on LU and it looks like lithium grease running out everywhere. Pulled bottom plug and doing out as well. I have never changed this oil before and the motor has extremely low hours. Is this normal, it this how it comes when new. Have a container of gear oil but this crap coming out is the consisity of grease. Been running out now for bout 5 min.
Sun Nov 20, 2011 7:35 pm
Post Re: Lower unit oil replacement problem
18x48 Charles Leonard / 36PD
Sun Nov 20, 2011 7:52 pm
Think the color is coming from the water that was in it from the seal leak. Have an air hose with a 1/4" fitting on top and have small sweep out bottom to get as much out as possible. The put the new chit.
Sun Nov 20, 2011 8:10 pm
Did you run it before you checked it?
Sun Nov 20, 2011 8:11 pm
Sun Nov 20, 2011 8:15 pm
LU seals were shot. Went see peck and got the new nut with three seals. Installed the new seals and wanted to change the oil cuz I new it was bad. Didn't run after replaced the seals. And here I am.
Sun Nov 20, 2011 8:20 pm
yep there you are!lol
Sun Nov 20, 2011 8:22 pm
Sun Nov 20, 2011 8:25 pm
Yep, thats what I though. Thanks guys.
Sun Nov 20, 2011 8:27 pm
i do mine every 50 hours with oil change cycle.
Sun Nov 20, 2011 8:28 pm
