It is currently Wed Sep 24, 2025 6:18 am
Reply to topic  [ 14 posts ]
 Props are all wrong!
Post Props are all wrong!
I was talking with robert4wd and looking at each others boat. we noticed that on my 23GTR the prop is stamped on the center of it the same as the 35GTR. i have been wondering about my prop from day one that it was huge and that it was a 35GTR prop. i turn 3500 with two guys in my boat with all my mods. i would think i would be closer to 4000 with my mods. when i picked my motor up at GTR it was right before lunch and they had rigged out another motor with a shorter shaft and was trying to put it on my boat when i noticed they had to set up the other motor besides it and hurry and get it all set up and was wondering if it might have got a 35GTR prop instead. What i need to know is there a difference in the 23GTR and 35GTR and what is it and how do i tell? Are they stamped different on the hub part and whats the 23GTR suppost to say compared to the 35GTR stamp?
Mon Nov 21, 2011 9:30 am
MMT Moderator
Post Re: Props are all wrong!
337-229-4864
ASK GATOR-TAIL....
GTB 1860 w/ 2019 GTR40XD-HO
Mon Nov 21, 2011 9:38 am
I'm pretty sure the 23's run an 11" prop.
Mon Nov 21, 2011 9:47 am
MMT Moderator
http://www.gator-tail.com/motors.html
Mon Nov 21, 2011 9:56 am
1" difference
1436 custom walked slowly by a 13hp Homemade LT.
The second amendment is what makes the first amendment possible.
Mon Nov 21, 2011 12:46 pm
With three guys in my boat (260, 230 and 205) my GTR23 on my 1540 chugs along at about 10 mph, sort of like a tug boat. No getting on plane with that much weight.
My prop is 11" in diameter.
Mon Nov 21, 2011 12:51 pm
I have 3 guys this past weekend 215,200,185 with 10 gallons gas, 4 dozen decoys, two batteries, 3 guns and 3 shell bags, and 3 stools and i was running 18 in deep and 20 in shallow in my 1648.
dguidry please tell me what is stamped on your prop between your blades. thanks!
Mon Nov 21, 2011 1:16 pm
Clickster, just measure your prop and if it's 12 inches, then it's probably for the 35hp. If it's 11 inches, it's probably the right prop (although I know GT did make an 11 inch prop for the 35hp at one time).
Mon Nov 21, 2011 1:29 pm
Mon Nov 21, 2011 1:34 pm
Mon Nov 21, 2011 1:47 pm
The 11" and 12" look the same and are stamped the same so you have to measure it.
Mon Nov 21, 2011 6:03 pm
The last 11" prop I seen was on Lil Peppy and it had some CUP on the blade tip, the 12" really dosent have much cup in the tip.
Tue Nov 22, 2011 7:11 am
Mine don't have much cup on the end and its 11 1/2 inches right now and I have 50 hrs on it.
Tue Nov 22, 2011 7:24 am
MMT Moderator
You probably have a 35 prop seeing as you have 50hrs and run SETX mud and have 11.5"
Call Gator-Tail about a new prop.
Tue Nov 22, 2011 7:32 am
