It is currently Wed Sep 24, 2025 6:19 am
Reply to topic  [ 17 posts ]
 2007 Prodrive lower unit problem
Post 2007 Prodrive lower unit problem
I just bought a 2007 32 prodrive. The motor runs great but i have what appears to be a oil/grease leak at the top of the lower unit right underneath the top skeg plat bracket. Does anyone one know how to address the problem. I spoke to a friend who is a mechanic who said to change the seals. I am just worried that i just purchased one with the bad lower unit which prodrive discontinued. Please Help Here is a pic
Thu Nov 24, 2011 10:01 pm
Post Re: 2007 Prodrive lower unit problem
How much does a new lower unit cost from PD
Thu Nov 24, 2011 10:02 pm
Used to be able to trade in your old one with 600 buck and get a new one.
Thu Nov 24, 2011 10:06 pm
Can i continue to run with this or its a need to fix asap problem?
Thu Nov 24, 2011 10:09 pm
Is it gear oil?
Thu Nov 24, 2011 10:15 pm
not sure, how to check? Just bought it yesterday
Thu Nov 24, 2011 10:17 pm
The smell is a 100% dead give away
Thu Nov 24, 2011 10:21 pm
Which would be?
Thu Nov 24, 2011 10:23 pm
Burnt popcorn and cunt hair. Idk man gear oil has a unique smell. Drain it and see if you have water in your Lu
Thu Nov 24, 2011 10:28 pm
I checked the LU oil it is very cloudy like, white
Thu Nov 24, 2011 11:01 pm
If you ran it today it will be milky. Let it sit for a day then check it again
Thu Nov 24, 2011 11:04 pm
You don't need a new LU. A seal change is in order and easy to do. Change the LU lube and run it. You will be fine till you get your lower seal from PD. I suggest getting a prop wrench and clutch pin (locks clutch to remove prop) while your at it.
18x48 Charles Leonard / 36PD
Thu Nov 24, 2011 11:20 pm
Thu Nov 24, 2011 11:21 pm
Fri Nov 25, 2011 11:29 am
On a huntch i filled the grease fittings with grease and watched all the old grease and water roll out. I kept pumping until i seen new grease. 8 hours later the leak never returned. I think it was just old brokedown grease coming out. Since it never smelled like LU oil i think i fixed the problem
Fri Nov 25, 2011 3:05 pm
Get some seals and a prop wrench,You will need them!!It is nice to have an extra seal and prop on hand ;)
Fri Nov 25, 2011 3:32 pm
Grease does not run. I change my LU gear lube often so I dont worry about what it looks like. You will be fine.
Fri Nov 25, 2011 5:09 pm
