It is currently Wed Sep 24, 2025 6:18 am
Reply to topic  [ 18 posts ]
 anybody try changing their top sprocket on 35hp gdsd
Post anybody try changing their top sprocket on 35hp gdsd
im running a 35gdsd with heads rockerrollers mukuni carb and evt exhaust ... im looking to get a little bit more speed out of her im running the stock 34 tooth right now turning up 4400 with new prop i just ordered a 36 tooth for it i was told it should bring my rpms down to 4200 and give me another 200rpm at the wheel......any good imformation will be appreicated ..
ITS NOT THE BOAT ITS THE OPERATOR!!!!!!!!!!
Fri Jan 06, 2012 3:09 pm
Post Re: anybody try changing their top sprocket on 35hp gdsd
Fri Jan 06, 2012 5:14 pm
i think yall mean pullys... not gears
I gave up mud motors
Fri Jan 06, 2012 5:25 pm
Gay ass go slow devil thread, best thing to do is sell that piece of shit and buy you a real upto date motor! Pulley's are for pussies!
Fri Jan 06, 2012 8:25 pm
Fri Jan 06, 2012 8:26 pm
Fri Jan 06, 2012 8:31 pm
bayou fagg i cant piss u off because u gotta change it out for me and ummm how many times has that peice of shit broken with over 700hrs on it?
Fri Jan 06, 2012 8:33 pm
Fri Jan 06, 2012 8:34 pm
robn i bought the "pulley" from coco at go-devil it cost me $90 he said it should help me but hes not for the upgrades on the motors lol......
Fri Jan 06, 2012 8:36 pm
hey bubba teets i didnt ask about u about a prodrive ur on the wrong thread buddy
Fri Jan 06, 2012 8:37 pm
Sat Jan 07, 2012 9:13 am
It's a pulley. Not a sprocket or gear you fuckkstickss
Sat Jan 07, 2012 9:36 am
i hope ur clutch goes out right after ur trim as$hole
Sat Jan 07, 2012 2:04 pm
Eat - Sleep - Hunt ! ! !
Sat Jan 07, 2012 4:06 pm
Man frik all these fukin prodrives keep smokin my ass .....in my jared!! voice
Mon Jan 09, 2012 11:03 am
Fri Jan 13, 2012 6:36 am
DB,
In his opening posts he said he had gotten a 36 tooth replacement from GD to change out
from the stock 34 tooth - do you have the math on those pulley ratios handy ???
Can anyone verify what the pulley tooth count on a stock 35 GDSD is for each pulley ???
I'm unsure but guess the stock setup is 48 / 34 @ 1.411
if that assumption is true then 48 / 36 = 1.333
or roughly a 5 % change like your example
Fri Jan 13, 2012 7:35 am
5.8% difference from 36 to 34
So if he is running 4400 RPMs and swaps the pulley (I assume Upper pulley cause the lower pulley is usually bigger) from a 34 to a 36 he will drop Approx 5.8% in RPMS which turns out to be 4,144 RPMs Roughly.
Making the top pulley larger is the same concept as making the bottom smaller... The closer you are to 1:1 ratio the more load you put on the motor and the Faster the prop will spin in relation to the crankshaft RPMs.
Fri Jan 13, 2012 7:44 am
