It is currently Thu Jul 10, 2025 3:17 pm
[ 7 posts ] |
backwater7
 pulleys and belts
could anyone tell me what type of belts and pulleys these SD motors require? would also appriciate if you could tell me where i can buy these parts any info would be great
Thu Mar 01, 2012 9:06 pm |
Quack Attacker89
Joined: Fri Feb 04, 2011 3:25 pm Posts: 92 Location: Alvin, TX
 Re: pulleys and belts
McMaster.com is a great sight to get pulleys. I bought my timing pulleys from there I think it was 18 tooth and 24 tooth for the gear reduction. I had to buy the hub also though so it would tighten on the shaft. I went with 1" belt width also.
_________________ 14' aluminum can powered by a 16hp GDLT
Thu Mar 01, 2012 9:16 pm |
backwater7
man thanks alot, im glad you answered my post
Thu Mar 01, 2012 9:22 pm |
lil goose
I got h-100 timing pulleys on mine with qd bushings
Fri Mar 02, 2012 12:53 pm |
Mag10
Joined: Wed Jan 14, 2009 12:31 pm Posts: 342 Location: Faribault, Mn
I go straight to a Gates distributor. McMaster is usually about 10-15% higher cost. Use the Gates Design Flex software to outline your drive and then send that directly to a local distributor for a quote.
Fri Mar 02, 2012 3:01 pm |
barrelburner
I agree mag10 mc master can be a little higher than other places. I got my pulleys from local outfit and they are top=TB16h100 kf-1 style and bottom=TB26h100 kf-1 for 1.63:1 gearing. I have also seen these pulleys on ebay and amazon at times. Also need to purchase the taper-lock bushings to go with this style pulley.
Fri Mar 02, 2012 3:34 pm |
backwater7
guys thanks so much everyone has been a big help
Fri Mar 02, 2012 5:06 pm |
[ 7 posts ] |
Users browsing this forum: No registered users and 35 guests |
