It is currently Mon Sep 22, 2025 10:54 am
Reply to topic  [ 12 posts ]
 Go Devil Lt PRop
Post Go Devil Lt PRop
I recently broke my prop on my 31hp gdlt. Im needing a new one but im a tad unsure of what to get. I spoke with godevil and they said the 31 and 35's come with a 10x4. I tryed to order this from my prop guy and he strongly discouraged me saying it was entirely to small. He recommended a 10x7. I was running about 3700rpm empty and 3550 Loaded with my old stock prop but it WAS pretty worn. What size do yall recommend?
17x54 custom CC with stage 3 GTR.
Tue Jul 21, 2009 5:50 pm
Post Re: Go Devil Lt PRop
That sounds small to me too.
Tue Jul 21, 2009 5:53 pm
If you still have the old prop it should be stamped by the threads I know my 23 hp is a 9x6
23 hp gdlt pushin the 14ft NoWeld "aka" the black pearl
35 hp gdsd pushin a 16/60 go devil boat
Tue Jul 21, 2009 6:15 pm
I'm perty dang sure Warren puts a 10 x 4 on there for a reason.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Tue Jul 21, 2009 8:00 pm
http://www.godevil.com/GO-DEVIL_Props.html
10x6 is the one you likely want --- it will put a typical MM hull up into
the 20 mph and up range with a load...
The 10x4 would be a powerhouse but quite a bit slower...
Call GD again... Talk to them about your hull and typical use as to
loads and types of conditions faced...
Eat - Sleep - Hunt ! ! !
Tue Jul 21, 2009 8:07 pm
I'm perty dang sure Warren stopped putting the 10 x 4 on there for a reason and now puts a 10 x 6. lol. Good call Giga.
Tue Jul 21, 2009 8:15 pm
In a commercial application - like pulling pipe or cable across a
shallow lake the 10x4 makes sense but for fishing and hunting
I bet you want that 10x6....
Unless you have mods or a super light hull the 10x7 and up
are likely to tall a pitch....
Tue Jul 21, 2009 8:26 pm
Tue Jul 21, 2009 9:34 pm
Where's Lance? I know he has put a new prop on his 35 longtail in the last year. He still couldn't outrun me but I was impressed with how fast his LT was. :D
Tue Jul 21, 2009 10:16 pm
If you were turning your 10x4 @3700 and it was worn down, you'll be lucky to spin a 10x7 3550 by yourself.
Freedom It Wasn't Free!!!
It Was Won!!!
Enjoy It!!!
The more you try to teach a stupid person something the dumber you get!!!
Tue Jul 21, 2009 11:09 pm
Definitely check your old one's stamping ! ! !
My GDLT 23 came with a 9x6 --- just like Backwaters
and I got about 21mph with a 16x48 GDSD hull
One revolution equals 6 inches of theroretical forward motion
The larger motor should turn the larger 10x6 blade well
unless the boat is a tank and you need a lower pitch
but I disagree with your prop guy on the 10x7 choice - cause
I tried one on my 23 and it was actually slower with 2 guys
and a load - but 2 mph faster solo @ 23mph - not a good
choice "all around" though on my rig....
Wed Jul 22, 2009 7:18 am
Also Bart from Go Devil tells me the current design 10x6 is different from the 10x6 of years past...
That GoDevil has been using a bit lower pitch than they used to with the newest logtail prop design....
So the moral might be that not every 10x6 or 10x7 will behave the same...
Might be differences from mfg to mfg....
Wed Jul 22, 2009 1:02 pm
