It is currently Wed Sep 24, 2025 10:09 am
Reply to topic  [ 8 posts ]
 Help removing prop shaft
Post Help removing prop shaft
How do you remove the prop shaft on a gator tail surface drive
Sun Jul 29, 2012 11:58 am
Post Re: Help removing prop shaft
Just the outdrive or the actual shaft from the outdrive?
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun Jul 29, 2012 12:08 pm
The actual shaft from the out drive
Sun Jul 29, 2012 12:11 pm
Please describe just the outdrive
Sun Jul 29, 2012 12:41 pm
Remove gear & snap ring, then front & real seals & bearings. Should be able to slide shaft out then.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun Jul 29, 2012 12:46 pm
35gtr on a 1854 Deep South Custom
1436 flat pushed by a 16 GDLT
Sun Jul 29, 2012 12:54 pm
Haven't messed with any older than 2010, didn't know there was a difference tho.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun Jul 29, 2012 12:56 pm
on the rear there is somekind of spacer on the octagon or whatever shaped part that i cant get off and i got the front seal out but cant budge the bearing shaft is bent any one got some pointers
Sun Jul 29, 2012 4:40 pm
