It is currently Wed Sep 24, 2025 6:45 am
Reply to topic  [ 2 posts ]
 Prop Wear ?
Post Prop Wear ?
I have a 31 hp mud buddy hyperdrive and the prop is only measuring 10 inches and is supposed to be 11. My boat will plane and run 5 mph faster in shallow water and throw a good rooster tail. I am pretty sure the prop is the cause for the slow speeds in deep water the rooster tail is weak in deep water also . I have heard a few different things about prop selection. Should I go with the stock prop at 11 x 10 or move to a bigger prop?
Wed Oct 03, 2012 5:54 pm
Post Re: Prop Wear ?
Unless your motor is modded or you have an EXTREMELY light boat and run lightly loaded all the time, you should probably go back with the same prop.
Wed Oct 03, 2012 6:00 pm
