It is currently Wed Sep 24, 2025 6:47 am
Reply to topic  [ 7 posts ]
 Hex prop adaptor
Post Hex prop adaptor
I have a home build 23 and would like to try and spin a big blade. I have cam/push rods/shims, mikuni, bps muffler, so I think I could spin one, but I don't want to design a new outdrive to switch from a 3/4" shaft to a 1" shaft. Do they make an adapter that will allow me to go from 3/4x10 threads to a hex design?
1846 GTB and 35 GTR
New GT Rig
Old Surface Drive Build
Sat Oct 13, 2012 7:05 pm
Post Re: Hex prop adaptor
Did you see this ?
http://bblades.com/product/bblades/lead ... propeller/
Wed Oct 24, 2012 6:57 am
Interesting...
Wed Oct 24, 2012 9:11 pm
I have seen those but don't know anything about them. It says they are for lt motors, and I have a sd.
1846 GTB and 35 GTR
New GT Rig
Thu Oct 25, 2012 6:14 am
I dont know if they would would work anyway for our size motor, they have a 9x7 and 9x6 i know my 20 runs a 9x4 at best
14 by 44 Weld Craft powered by a 20hp. go devil longtail
Team Arc Angel Bowfishing
Thu Oct 25, 2012 6:48 am
Just because they are for Lt doesnt mean they wont work for a sd; the prop might not be right but the hex might fit other props that are hex...... if its a 3/4" shaft it would make that 3/4x10 threaded area hex compatible.... however if the hex is comparable to a sd hex prop would be the real question.
1436 Lowe
Thu Oct 25, 2012 10:26 am
The sd hex props fit a 3/4" hex, so you wouldn't be able to use a 3/4x10 adapter and make it work. Maybe this company will start making some bigger props.
1846 GTB and 35 GTR
New GT Rig
Thu Oct 25, 2012 12:09 pm
