It is currently Sun Sep 21, 2025 5:47 am
Reply to topic  [ 6 posts ]
 replacing tension knob on PD 36
Post replacing tension knob on PD 36
My tension knob for the lower unit is stripped and just spins, affecting FPR ability. It is the old style handle.
Has anyone had this happen?
How to you get the old handle off? Pull and turn does not seem to work.
I will call KP on Monday to send out a new handle.
Sun Sep 13, 2009 11:32 am
Post Re: replacing tension knob on PD 36
turn it to da left....
or turn it counterclockwise....
(which is da opposite of clockwise.)
good luck.
P.S. How in da hell did u strip it anyways?
Sun Sep 13, 2009 12:36 pm
Is the black knob stripped out or the threads in the aluminum mid section?
The black knob should have stripped out before the mid section threads! you would think anyways?
Any which way, just get a pair of vise grips lock them onto the threaded part/bolt of the knob and turn it counter clock wise and pull out at the same time. it should back on out. If the threads are stripped then a Heli coil would probably be the easiest fix.
http://www.helicoil.in/
also X2 on HTF?
Sun Sep 13, 2009 1:10 pm
Yeah, the plastic turn knob is stripped, not the actual threaded part into the LU.
Mon Sep 14, 2009 7:42 am
Mon Sep 14, 2009 10:56 am
See if you can find a T-handle replacement at Lowes or HD.
18x48 Charles Leonard / 36PD
Mon Sep 14, 2009 11:03 am
