It is currently Sun Sep 21, 2025 9:08 pm
Reply to topic  [ 16 posts ]
 New prop... Installing question
MMT Moderator
Post New prop... Installing question
How tight or is their a specification of how many FT/LBS I should tighten the nut that holds the prop on? Once there's no play in the prop etc.
GTB 1860 w/ 2019 GTR40XD-HO
Wed Sep 23, 2009 8:21 am
Post Re: New prop... Installing question
The prop is thread on and every time you hit something it gets tighter so I put the prop on and tighten the nut snug and run for a while and the check the nut on the back and see if it needs to be tightening again. I do not know if there is a spec for how many ft/lbs.
1652 w/ MB Mini 35
Wed Sep 23, 2009 8:39 am
GT uses a hex shape for their props they are not threaded on.
I don't know maybe you can call GT or wait for a response on here
When in doubt, throttle out.
18x60 prodrive w/36 prodrive
Wed Sep 23, 2009 8:46 am
I just put it on and snug it down and I have never had an issue,its got a lock nut on it so there is no need to torque the piss out of it.
Wed Sep 23, 2009 9:30 am
MMT Moderator
I know they aren't threaded my question was about the nut. I think I got it answered... I'll call Hoyt if I have any questions but was making sure if I snug it up I'll be good...
Wed Sep 23, 2009 11:25 am
i just tighten mine till i go...uuugh! :D
cajun: its real simple, we live back hea', dis' is our home, an' nobody don' fuk wit' us!
Wed Sep 23, 2009 12:54 pm
German torque spec Good-n-tight.
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Fri Sep 25, 2009 7:00 am
Tighten it up and hit the wrench a couple times with a hammer and your good to go.
Fri Sep 25, 2009 7:20 am
60ft.lbs. according to the GT owners manual on the GT website.
Fri Sep 25, 2009 8:59 am
Fri Sep 25, 2009 9:03 am
Hamma and duct tape to keep the prop from tuning will get ya in da right TQ specs! :lol:
Bayou Surface Drive
337-351-0362
Fri Sep 25, 2009 9:28 am
and once you have the nut good an snugg you might want to hammer the end of the shaft too! you know kinda mushroom it over a bit just to be safe ;)
Fri Sep 25, 2009 9:56 am
Fri Sep 25, 2009 11:53 am
MMT Moderator
Fri Sep 25, 2009 1:54 pm
1754 GT EXTREME 37EFI
Fri Sep 25, 2009 6:50 pm
Fri Sep 25, 2009 6:59 pm
