It is currently Sun Sep 21, 2025 8:32 pm
Reply to topic  [ 11 posts ]
 Hydraulic Oil Leak PD36
Post Hydraulic Oil Leak PD36
One of the lines for my hydraulic trim blew a leek today and had to ride back to the boat lauch with motor trimmed all the way down.
Every time I fix something I learn so here it goes:
What kind of hyraulic fluid? Farm and Fleet?
The line I am talking about is the corrigated metal line, there are two of them, going from the trim motor to the trim cylinder.
Is it special line, where can I pick them up at?
Last question, and I am no mechanic, but what are the steps to put the hydro in it? I can't even find a fill spot on the trim motor.
Thanks for any help, it is much appreciated.
Sat Sep 05, 2009 6:16 pm
Post Re: Hydraulic Oil Leak PD36
On the trim motor just above the oil resivoir you will find a dipstick with a flat head screwdrive slot in it. Trim the motor up then fill it there using a oil squirt can, is what i use. The fluid is dextron III transmission fluid. And the hydralic hoses you can get from your local prodrive service center or at any Napa auto part store, or any hydralic hose speciality store. 1/4" stainless braided hoses aren't cheap i'ma warn you.
1754 GT EXTREME 37EFI
Sat Sep 05, 2009 6:39 pm
Thanks LA.
I saw the screw slot. How much hydro does it need?
I will have to put something under the prop because the only way I can trim it up is to lift the motor...my back is shot. :x
If I replace one line I don't know if I should replace the other. Is one line an intake and the other out?
Do I need to blow the lines? Not even sure how to anyway.
Thanks again. Trying to more scouting this weekend.
Sat Sep 05, 2009 7:04 pm
Sat Sep 05, 2009 7:15 pm
How much oil do I need?
Sat Sep 05, 2009 8:06 pm
If you buy one quart you will not use it all. just squirt some in and screw the dipstick in then pull it back out and check it. Add oil if needed.
Sat Sep 05, 2009 8:08 pm
Replace both hoses.You DO NOT Need to use wire braided hoses.Go to your local NAPA or Someone who makes hoses and tell them you need 5000psi or more hoses made to the same length and same fittings.Cost me $26 for two rubber hydraulic lines.
Sun Sep 06, 2009 10:25 am
Sun Sep 06, 2009 9:43 pm
I call PD. They asked for my address and in a day or 2 I had a new one.
Thu Oct 01, 2009 11:05 am
Good Deal!
Thu Oct 01, 2009 8:24 pm
I did the same thing a while back and peck had them at my door step the following day....Very fast
Thu Oct 01, 2009 8:28 pm
