It is currently Sun Sep 21, 2025 1:39 pm
Reply to topic  [ 9 posts ]
 Prop Removal
Post Prop Removal
Ive heard all these horror stories about trying to get a prop off of a long tail is a realllll pain.. Whats the easiest way to remove a prop? any info will be appreciated.
16x60 GD Tank with a 35 GDSD
Thu Oct 08, 2009 11:35 am
Post Re: Prop Removal
Bind the shaft and un screw the prop. Come on man you work with tools every day. :)
BUCK OFAMA
Thu Oct 08, 2009 1:15 pm
You could make yourself a prop tool with a nut, piece of pipe, and two pieces of flatbar. Weld a nut onto a piece of pipe that will fit over the shaft. Weld the flatbar to the pipe, one on each side facing counter-clockwise when looking at the nut. When you slide the pipe over the shaft and rotate it CC the flatbars should fit against the backside of the blades. Stick a rod through the u-joint to stop the shaft from turning. Make sure the rod is not on the same side of the cross as the zerk is. Put a socket and impact on it and it will come right off.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Thu Oct 08, 2009 7:45 pm
alright thanks for the info,
thats alot of helpful info there bj.... Sinceee your off right now go take it off lol
Fri Oct 09, 2009 5:58 am
BUCK OFAMA
Fri Oct 09, 2009 8:00 am
You bring your work truck with all the tools and yank it off. Be my guest!
Mon Oct 12, 2009 11:15 am
cajun: its real simple, we live back hea', dis' is our home, an' nobody don' fuk wit' us!
Mon Oct 12, 2009 5:07 pm
I fought mine the first time I took it off. Called Bart baker and he told me when you put it back on tighten the prop all the way tight then back it off about a 1/4 turn then put the rest of the nuts and washers on tight. First time I pulled the prop it took me about 3 hours took it off yesterday and it took me about ten minutes.
23 hp gdlt pushin the 14ft NoWeld "aka" the black pearl
35 hp gdsd pushin a 16/60 go devil boat
Mon Oct 12, 2009 6:01 pm
I have access to justt about anything i need to make that prop wrench, ill dig around and work tomorrow and see what i can come up with. Thanks for all the info guys!
Mon Oct 12, 2009 6:23 pm
