It is currently Thu Jul 10, 2025 12:21 pm
Reply to topic  [ 28 posts ]
 Getting a prop off
Post Getting a prop off
Anyone in the Baytown area that i could meet up with Friday afternoon that has a prop tool for a Go-Devil? Or does somebody have a good way to get a stuck prop off without a tool?
Wed Apr 09, 2014 7:48 pm
Post Re: Getting a prop off
Find a box end wrench that will fit the shaft and hook the blade then put a cheeter pipe on and hope for the best.
20' homemade skiff with a stage 2 gtr
Wed Apr 09, 2014 8:07 pm
I ground down an old shitty 10" crescent wrench so it fits ahead of the prop on my copperhead. then I duct tape a chunk of 2X4 on the head of a 10lb sledge hammer and go to town on it.
13' Jefferson fiberglass skiff - 14 Copperhead
Wed Apr 09, 2014 8:41 pm
Wed Apr 09, 2014 8:44 pm
Thats what I used to do lol didnt sound to professional though lol.
Wed Apr 09, 2014 8:45 pm
When all else fails. , you can always resort to this . A new prop was going on anyway .
H Finn
GATOR GLIDE PROSTAFF
BACKWATER PROSTAFF
http://www.gatorglide.com
Coupe rest in peace brother
Wed Apr 09, 2014 8:49 pm
Get go devil to ship you a prop wrench. They work great
40HP Gatortail
Wed Apr 09, 2014 8:58 pm
That's not needed
Sent from my iPhone using
Wed Apr 09, 2014 9:08 pm
1854 Extreme CC 35 GTR
RTR!!!
Wed Apr 09, 2014 9:13 pm
Wed Apr 09, 2014 9:16 pm
I took a 5 foot 2x4 and a tow strap. Wound the strap around the blades of the prop and the 2x4 at the same time. Then spin the shaft with the wrench until the strap is nice and tight "on the board and the prop". Then dog the wrench off on something hard "I used a cement block" then give it hell.
1648 GDSD 27 GDSD
Thu Apr 10, 2014 2:02 am
I thought the PD was tough to get off. HAHA. By the way, it may or may not work on yours but a 3' crow bar works great on a PD. Loosen the nut and leave it on, rest the bar on the nut and the hook will "hook" around a blade and get with it. If the right tire of the trailer doesn't come off the ground, you're not putting enough ass behind it :lol:
Thu Apr 10, 2014 5:11 am
3lb dead blow hammer you can beat the shit out of it. Should't hurt anything.
Thu Apr 10, 2014 5:31 am
Beating on it may not work for a prop that's stuck pretty good - there's too much twist in the shaft. I used a piece of flat bar and cut a hole in it to fit over the shaft as a makeshift prop tool and it still wouldn't budge until I used the flame wrench to heat up the prop.
Thu Apr 10, 2014 5:46 am
Shit load of anti seze before ya put it back on.
Thu Apr 10, 2014 5:50 am
I used a 48" pipe wrench sideways (jaw opening facing the prop nut) and a 24" on top to bind up my U joint and pulled like hell. I heard a badass pop and I busted my ass and thought I broke the shaft but it was just the prop breaking loose. Spun it off by hand after that. I take it off every few trips out now and lather it down with never seeze just to prevent that sorta thing :lol:
-Custom pool noodle
-stage 4 water wings
Thu Apr 10, 2014 5:59 am
MMT Eternal Member - Rest In Peace
Worse come to worse take a cut off wheel and at the thinnest part of the hub. cut a grove down to the.shaft the same direction as the shaft. Then smack it. If you've done it right it will spin off.
These shaft threads get clogged up with mud and sand. With the new prop if you take it off atleast twice a year and clean and install antisieze they normally don't stick like this
Thu Apr 10, 2014 7:35 am
Thu Apr 10, 2014 9:25 am
Where the heck you running? Volcanic ash swamp? You've got something wrong if you've blown through 7 props in 8 months. Us this a cheap sps set up with aluminum props?
At $225 a gd prop that shit would be expensive :lol:
Thu Apr 10, 2014 11:28 am
Thu Apr 10, 2014 11:51 am
I got a prop u wont burn through that quick
Thu Apr 10, 2014 12:01 pm
1744 WC Custom
25 GTR
Thu Apr 10, 2014 4:20 pm
i can rebuild that for u js
Thu Apr 10, 2014 5:04 pm
Thu Apr 10, 2014 8:01 pm
I can sell u one u can't wear out in a month
Thu Apr 10, 2014 8:13 pm
Pick axe handle with a 7/8" hole
Cresent wrench on prop nut - maybe use an extension on the wrench (dom tube)
B. MacDonald
Fri Apr 11, 2014 8:57 am
^^this. I used a 4' piece of 2x4 but the same concept. If you can't bust it loose with a 4-5' handle you are probably going to have to cut it. I have never had any luck beating on one with a hammer or anything else for that matter.
Fri Apr 11, 2014 11:13 am
I built a homemade tool in my shop class today. It came right off
Fri Apr 11, 2014 3:43 pm
Users browsing this forum: Google [Bot] and 44 guests
