It is currently Thu Jul 10, 2025 4:55 pm
Reply to topic  [ 6 posts ]
 Engine Push
Post Engine Push
My engine pushes into me when up on plane, it is a bear to drive. What are some tips and tweaks to balance out that prop torque when running open water? If it is just me in the boat it rolls (as if driving through waves) in calm water, is that normal? I read a triple blade prop helps, is that true?
I run a 1648 weldbilt, 23 hp MBSD with Mikuni carb and after market exhaust. I have the stock prop on still.
I couldn't quite find the right key words in search, so if you know of some good threads that already explored this, please point me to the .
Sun Jun 08, 2014 12:23 pm
Post Re: Engine Push
Weight distribution is paramount when it come to tiller torque
Sun Jun 08, 2014 12:32 pm
3 blade is a lot worse on my gtr as far as tiller torque versus my 2 blade
HOTSAUCE170 wrote:
Sun Jun 08, 2014 1:29 pm
Is it square on the transom?
Fri Jun 13, 2014 10:49 pm
Couple of things. You can offset your motor on the transom by 1/4"-3/8" to the port side. The other is to adjust the bent portion of your skeg under the prop. If its pushing into you, you may need a little more angle. Take a 2' or 3' piece of 4x4 pine and cut a kerf in the end of it the thickness of the skeg and use it as a wrench to put a little more bend in it.
Sat Jun 14, 2014 5:51 am
Try trimming down a bit or get out the GPS and find the sweet spot, then if you still have tiller torque adjust your skeg.
Sat Jun 14, 2014 2:02 pm
Users browsing this forum: No registered users and 46 guests
