It is currently Thu Jul 10, 2025 3:47 pm
Reply to topic  [ 15 posts ]
 Greased shaft and water came out: seals need changing?
Post Greased shaft and water came out: seals need changing?
What's your diagnoses and remedy?
Sat Oct 11, 2014 7:32 am
Post Re: Greased shaft and water came out: seals need changing?
Keep grease in it at let er eat!
Sent from my beeper
Sat Oct 11, 2014 7:48 am
Can't rely on West Monroe advice :lol:
But, seriously, are there seals where the shaft joins to belt housing which could leak or is it more likely the shaft seals near the prop?
Sat Oct 11, 2014 8:22 am
Id say by the prop. I've seen almost all mb do that, that's why I liked to grease mine more often
Dead Fowl Custom 1954hd with a GTR
Sat Oct 11, 2014 8:34 am
change seals mine was doing that during crawfish season and i waited like everyone said and i bought a new shaft cuz mine had a griooves cut in it from under the bearing sleeve
20' homemade skiff with a stage 2 gtr
Sat Oct 11, 2014 12:33 pm
Eat - Sleep - Hunt ! ! !
Sat Oct 11, 2014 1:22 pm
Sun Oct 12, 2014 2:32 am
New seals (and bearings). Water can't get to the shaft at the belt housing end unless there's water in the belt housing. So if the prop side isn't leaking, you got a leak in the belt housing that needs dealt with along with the seals. The drain in the bottom of the housing was leaking on mine, but a little silicon around the threads took care of that. And yes, there are seals at both ends of the shaft. More than likely prop end, though.
Sun Oct 12, 2014 10:18 am
Sun Oct 12, 2014 12:23 pm
Go-Devils are still the seal eatingist motor out there
Mon Oct 13, 2014 4:24 am
O.O Godevils have seals?!
Mon Oct 13, 2014 6:24 am
Thanks for the advice gentlemen.
Mon Oct 13, 2014 7:11 am
WC Custom 1854 huntdeck pushed by MB7000
Fri Oct 17, 2014 5:26 am
Sat Oct 18, 2014 6:40 am
Mon Oct 20, 2014 9:45 am
Users browsing this forum: No registered users and 34 guests
