It is currently Sat Jul 05, 2025 4:08 am
Reply to topic  [ 8 posts ]
 Broken grease bolt on GTR37
Post Broken grease bolt on GTR37
I managed to over torque my drain plug after pumping fresh grease in my upper zerk. I noticed that the plug had a hollow shaft as pictured. Is there a reason that this is designed this way or could I get away with just replacing it with a same sized bolt?
Sun Sep 20, 2015 7:47 pm
Post Re: Broken grease bolt on GTR37
Is that the new lower unit? My guess is that it is a pipe thread and not a regular bolt. It looks like a brass pipe plug. I would replace with the same in case it ever gets broke off it will be easier to remove.
Sun Sep 20, 2015 7:54 pm
It's going to have different threads than a bolt. Go to a hardware store or big box home improvement store and match it up.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Sun Sep 20, 2015 7:57 pm
Damn u lucky it broke and not cracked the cast LU. That's probably an NPT thread like others have said.
Sun Sep 20, 2015 8:04 pm
Yeah, it's on the new lower unit. I found a matching size/threaded stainless bolt at lowes that will work. I just wasn't sure about it having a hollow shaft. I'm gonna call gator tail in the am and ask them. It just drives me crazy when stuff like this happens over the weekend.
1754 Gatortrax / GTR 37 EFI
Sun Sep 20, 2015 8:07 pm
Even if the threads "match" the plug you broke is tapered. A bolt will never tighten up in that hole till it bottoms out. A pipe plug is tapered so it gets tighter the farther you thread it in.
-get a correctly sized pipe plug for it and don't ovrrtighten it. It doesn't have to be retarded gorilla tight.
-Custom pool noodle
-stage 4 water wings
Mon Sep 21, 2015 3:38 pm
Yeah, that's what I got. Just like this one.
Mon Sep 21, 2015 9:01 pm
10-4, put any Teflon on it? Don't know if GT recommends it but I can't see it being a bad thing...
-Custom pool noodle
Mon Sep 21, 2015 9:57 pm
Users browsing this forum: No registered users and 62 guests
