It is currently Fri Jul 04, 2025 11:19 pm
Reply to topic  [ 18 posts ]
 Gen2 prodrive skeg
Post Gen2 prodrive skeg
Hey guys I run a bunch of hard bottom up my direction and noticed that my skeg is preventing me from getting good bite from time to time, I know a couple people have trimmed theirs and that Bayouboy makes some. Just wanted to see what my options are to help with this situation, pics would be appreciated!
1854 Uncle J sport deck with a 36 prodrive
When in doubt throttle it out!
Thu Sep 24, 2015 12:19 pm
Post Re: Gen2 prodrive skeg
Wish I could get one of those fancy skegs also.
Fri Sep 25, 2015 3:58 pm
Here's my DIY skeg.
Fri Sep 25, 2015 5:10 pm
Still have a little more touching up before I put the GG to it.
Fri Sep 25, 2015 5:16 pm
Fri Sep 25, 2015 5:44 pm
Yes....allows churned up mud and water to reach the prop much more efficiently. I see no difference in performance when it comes to putting my boat on a step. So, I would rather have performance where it counts.
Fri Sep 25, 2015 5:56 pm
Fri Sep 25, 2015 6:27 pm
It makes a huge difference in the thick stuff. Let's that regurgitated pancake batter, concrete mix....whatever you want to call it....get to the prop. The vertical AND horizontal plates don't allow the prop to suck stuff into it as good as it does without. With, the prop will blow out more than without.
Fri Sep 25, 2015 10:31 pm
Just be careful when putting in reverse.
Sat Sep 26, 2015 7:41 am
It just makes a lot of noise if you trim down too far.....you'll know! LOL
Sat Sep 26, 2015 3:48 pm
Mon Sep 28, 2015 4:56 am
I have a cut stock one. Leave the torque tab on it. Most of the meat off else where, but leave as much as possible between the tower and the transom. this will limit the build up of vegetation between the motor and boat. All you are trying to so is help the outdrive angle.
1754 XSeries Kawi Powered PRODRIVE ...
Mon Sep 28, 2015 8:03 am
Buddy, can you post a pic?
I am trying to decide whether to cut down the stock or cut a new one out. Everyone seems to agree that they perform better.
Can anyone comment on performance over a hard bottom? Will it allow you to run and or recover better when bumping bottom on plane?
Mon Sep 28, 2015 8:40 am
Buddy of mine runs a cut down stocker and its not the same. The drive angle sucks on the PD for hard sandy bottom, but the skeg helps. I also took the wedge off my stock one and welded it to prestons to help with the tiller torque.
Mon Sep 28, 2015 10:43 am
Mon Sep 28, 2015 11:31 am
Mon Sep 28, 2015 11:41 am
Thu Oct 01, 2015 8:04 am
Thu Oct 01, 2015 10:51 am
Users browsing this forum: No registered users and 76 guests
