It is currently Wed Jul 09, 2025 7:56 am
Reply to topic  [ 7 posts ]
 Help trim problem!
Post Help trim problem!
Been having a problem with my trim not wanting to go down but goes up just fine. Motor is a 2011 mud buddy hyper sport with merc trim. When attempting to trim down I can here something attempting to engage but nothing happens. It sounds like a rotating noise. Sometimes the trim works fine though. Help me please!!
2010 1650 xpress with mud buddy 35 hypersport
Sat Sep 26, 2015 7:41 pm
Post Re: Help trim problem!
They got two solenoid fuses on the right side of the motor underneath that black plastic piece, think they 30 amp fuses they common for going out on those motors
Sat Sep 26, 2015 8:25 pm
Could be the magnets come unglued inside the pump motor case. Motor will turn inone direction, but when reversed the magnets shift and lock up motor. Thus tripping the breaker. When breaker resets it self and motor is tried again magnets shift enough to allow motor to run. Until the next time. Sounds like a probablem I had on a Mercury trim pump motor. Motor will eventually lock up and won't run either direction. New pump motor From Mercury $123 on Amazon .com #809885A for the exact replacement motor. Good Luck getting any help from MB on this issue, they don't warrant them. Had one fail with under 70 hrs on it.
Sun Sep 27, 2015 6:33 am
I sent you a pm. Not sure of your dealer but Boat Dr is a sponsor and he is good on these issues.
WC CUSTOM 20X54 Battleship w/ Gator Glide Pushed & Pulled hard by an HDR!
Don't be scared...Hit It and Hold It!!!
Sun Sep 27, 2015 9:52 pm
just had similar problem. my fix was the breaker. yours could be breaker or relays
1748 Prodigy with MB 4500 Black Death
Mon Sep 28, 2015 6:44 am
Here is a step by step way to troubleshoot the Merc Trim.
http://www.mudbuddy.com/forum/showthrea ... rcury+trim
Common problems with it trimming one way and not the other is either the trim relays or the switch. Not sure where your trim relays are mounted but find the solid colored green (down) and blue (up) wires coming out of the relays going to the trim motor- they have black waterproof bullet connectors on them. May be tie wrapped up in the wire bundle, the green and blue striped wires are the control wires from the relays to the switch in the tiller. Just swap those two solid colored blue and green connections and see if the problem moves to the other direction. This tells you the switch is not the problem and its probably one of the relays going out.
Mon Nov 02, 2015 5:59 am
Mon Nov 02, 2015 6:05 am
Users browsing this forum: No registered users and 47 guests
