It is currently Fri Nov 14, 2025 11:09 pm
[ 5 posts ] |
strange noise from clutch
JW127
Joined: Sun Feb 28, 2010 10:01 am Posts: 4 Location: Caddo Lake, Texas
Got a 32 hp PD with 160 hours with a new lower unit with only about 25 hours on it and my clutch has started to make a strange noise after it disengages while using the pulse switch. It sounds like something maybe coming loose and makes a strange sounding vibration but it only does it some times. Any thoughts on whats causing it?
| Fri Mar 05, 2010 8:38 pm |
caddobrook
 Re: strange noise from clutch
I would call KP at Prodrive. He is very helpful and can get you sorted out....
| Fri Mar 05, 2010 9:02 pm |
craig
| Fri Mar 05, 2010 9:12 pm |
naj
Joined: Fri Jan 22, 2010 8:40 pm Posts: 1620 Location: Larose, Louisiana
I experianced the same noise. Clutch went out a few hours later. Its not a good feeling knowing you cant get home due to the clutch not engaging.
They run just under 200 bucks and can be changed out in an hour if you are a little handy with tools.
_________________ 18' X 48" Center Console Sportsman Fab with a Yamaha F70LA 18' X 48" Center Console Sportsman Fab Dragging a 36hp ProDrive 15' X 42" Sea Arch with a 27hp ProDrive
| Fri Mar 05, 2010 10:36 pm |
ff154
Joined: Mon Nov 30, 2009 12:02 pm Posts: 78 Location: Marshall, TX
Don't stray too far from Swansons to run those lines!
Check your inbox man.
_________________ Breaux skiff, 36 PD
| Sat Mar 06, 2010 4:47 pm |
[ 5 posts ] |
