It is currently Fri Jul 04, 2025 4:46 pm
Reply to topic  [ 3 posts ]
 Best replacement prop- 16hp GD Crawfish
Post Best replacement prop- 16hp GD Crawfish
Looking for a new prop and didn't know if I should just stick with factory setup. Specs below. Thanks in advance.
GoDevil 16hp Crawfish (shorter tail, 54" I believe)
15/48 Seaark(semi-v I guess, not flat bottom)
Running backwaters mostly littered with logs and other trash. Need to be able to push through skinny water new and when it's falling out. Usually two or three men and gear.
Wed Sep 07, 2016 7:55 pm
Post Re: Best replacement prop- 16hp GD Crawfish
The go devil prop will be hard to beat. At least from my experience when I had my long tail. If you call Coco at go devil he will give you the best advice. He knows his motors and what prop will run best if you give him the same info as stated above.
Fri Sep 09, 2016 8:32 pm
When I still ran a longtail the best props in regards to wear came from Stump-Jumper and BBlades.
Thu Sep 15, 2016 6:54 am
Users browsing this forum: No registered users and 53 guests
