It is currently Mon Sep 22, 2025 4:04 pm
[ 6 posts ] |
Mud buddy 35 bearing replacement
dcmab
Hello everyone. Been a few years since I posted. Surprised I remembered my log on haha.
I searched on google and can't find a write up on this. The search on the mobile forum won't work.
I'm currently in the middle of taking apart the lower unit. I am currently stuck. The collar is stuck on the shaft and I need to either heat it up or use some wood and bang it off. I can hear and see bad bearing already by the prop. I may as well replace all 4. My question is.... what all do I need to order? I'm hoping my shaft isn't scarred up. If I get it Un stack and find the shaft js screwed. I'll order that too.
Wed Aug 30, 2017 7:58 pm |
Russ
 Re: Mud buddy 35 bearing replacement
Are you talking about the collar the rear bearings ride on?
Wed Aug 30, 2017 8:26 pm |
dcmab
Yes. Their is a collar on both sides of the shaft. I've got the reverse thread cap off. So the collar is exposed on both sides now.
Thu Aug 31, 2017 2:23 am |
Russ
It's screwed on too. Don't beat it off. Get a good strap wrench unless you're gonna buy another. In that case you could just get a pipe wrench on it.
Thu Aug 31, 2017 8:54 am |
dcmab
Not the collar with the pulley. The collar on the actual shaft. The collar the pulley uses was seized and cracked. It broke in half when I took it out.
Thu Aug 31, 2017 9:20 am |
Russ
Pm sent with my number.
Thu Aug 31, 2017 2:00 pm |
[ 6 posts ] |
