It is currently Sat Jun 15, 2024 3:41 pm
[ 6 posts ] |
muddymunsters
Zerk fitting
I have a 2012 35 Gator tail. Is the zerk fitting on this suppose to have a ball? Dude at hardware store sold me without one, said that not all zerks have a ball. Installed it today, greased it up, and as expected, grease was coming out of the port hole.
I need to know if the original zerk was one with a ball because it may be in the shaft. Thanks
Sat Dec 02, 2017 5:16 pm |
DENNYEDWARDS
Joined: Sun Aug 09, 2009 12:50 pm Posts: 574 Location: Muscatine, Iowa
Re: Zerk fitting
Every one I've seen in that application has a ball check zerk. Need to keep water out of prop shaft tube. I would grease tube then remove zerk and install a 1/4 20 set screw in its place sealed with a good waterproof sealent.
Sat Dec 02, 2017 7:36 pm |
jc
Re: Zerk fitting
Yes it should have a ball. The ball on your old one should not have been able to get to the shaft, there is a spring behind it that keeps it pushed out to seal it off. It popped out to the outside. Just get a new one with a ball and you will be fine.
Sat Dec 02, 2017 8:38 pm |
muddymunsters
Re: Zerk fitting
Thank you
Sun Dec 03, 2017 6:06 pm |
deucem
Re: Zerk fitting
_________________ 2010 GTR35 pushing an 1860 Gator-Tail Extreme
Thu Dec 07, 2017 10:30 am |
jc
Re: Zerk fitting
Thats not good. If it were mine I would pull it apart and clean it out just to be safe.
Thu Dec 07, 2017 6:01 pm |
[ 6 posts ] |
Users browsing this forum: No registered users and 134 guests |
