on da bayou
![Post Post](./styles/acidtech_tiger/imageset/icon_topic_latest.gif) Gear teeth on my 2012 gtr
I have a 2012 35 gtr With hydraulic reverse wanting to know how many teeth or on the top pulley and how many teeth is on lower pulley on a stock gtr also what is the prop size and Pitch it is in a two blade and a three blade if any one know
Mon Jan 08, 2018 5:41 pm |
![](./styles/acidtech_tiger/theme/images/spacer.gif) |
bluesky2012
![Post Post](./styles/acidtech_tiger/imageset/icon_topic_latest.gif) Re: Gear teeth on my 2012 gtr
Take the transmission cover off. It'll have a 48 stamped on either the right or left side if it is 48
Mon Jan 08, 2018 6:05 pm |
on da bayou
Mon Jan 08, 2018 8:24 pm |
bluesky2012
The bottom is 48. The top is what ever you count to. I don't think the top has ever changed. I think the ones changed around 2012 went from 42 to 48 but I may be backwards.
Mon Jan 08, 2018 8:27 pm |
Russ
The bottom used to be 45, changed to 48 around that time. The top is 36, I think. Marcus will be along shortly to correct me if it's 38.
Mon Jan 08, 2018 8:36 pm |
on da bayou
Mon Jan 08, 2018 8:37 pm |
Russ
12x10
Mon Jan 08, 2018 8:39 pm |
on da bayou
Mon Jan 08, 2018 8:40 pm |
bluesky2012
If Russ says it is, then it is. Thanks for the correction on 45 and not 42. Drinking beers and watching Alabama hopefully lose doesn't make for a strong memory of obscure facts.
Mon Jan 08, 2018 8:43 pm |
on da bayou
If u always have to push away with the tiller handle from u which way should I bend the tabs thanks
Mon Jan 08, 2018 8:48 pm |
bluesky2012
Away from you. Check your weight distribution first and also prop plays into effect. Since you have a worn prop, may want to wait till you have a new one and see how that plays in.
Mon Jan 08, 2018 8:51 pm |
Russ
Trim level affects the felt torque a lot, and a fresh prop will change where it's trimmed for best thrust. Unless you're gonna use that prop a while, just wait on the bending stuff.
Mon Jan 08, 2018 8:55 pm |
on da bayou
Thanks baggy’s got my prop now to get work
Mon Jan 08, 2018 9:09 pm |
MaXXis85
Top gear is 38 Current bottom is 48. Used to be 45 lower, but was changed around 2011-2012 ish. The CDI motors additional charging system put more load on these units aswell as larger boats, 3 blade propellers were coming out; so they needed a lower gear ratio. 38/45 = 1.18:1 38/48 = 1.26:1
Tue Jan 09, 2018 6:18 am |
CypressCritter
Joined: Tue Aug 26, 2014 10:36 am Posts: 822 Location: Jefferson TX
I have a 2011 GTR CDI
its a 38/45 and came stock with a power tech 12x10
_________________ SEAARK FX 2472 CC Merc 150HP 4Stroke(CypressCadillac) Uncle J Custom - 19x54 CC Skiff w/40XD GTR
Tue Jan 09, 2018 10:39 am |
pokey79
Joined: Mon Nov 15, 2010 4:50 pm Posts: 2282 Location: Circumcised, Louisiana
Tue Jan 09, 2018 1:51 pm |
on da bayou
Thu Jan 11, 2018 7:41 pm |
MaXXis85
Port side top of belt box.
Fri Jan 12, 2018 7:36 am |
