It is currently Sat Sep 20, 2025 11:35 pm
Reply to topic  [ 17 posts ]
 Need P/N for PD Lower Seals
Post Need P/N for PD Lower Seals
Pissed to see that my LU oil has gone chocolate milk again. Season starts this weekend for us out west. Hoping to get some new seals in the motor before then. Can anyone provide the P/N for the seals so i can see if I can find them local? Motor's got a 7/8" prop shaft.
32 PD with EVT cam, decked heads, shaved pistons and not enough sense to leave things alone!
Mon Oct 15, 2018 8:44 pm
Post Re: Need P/N for PD Lower Seals
sierra 18-10127 is what it use to be unless they changed it.
Tue Oct 16, 2018 6:38 am
Thanks, banded
Tue Oct 16, 2018 12:00 pm
as long as their is fluid in the lower unit, run it. fix it later.
Tue Oct 16, 2018 6:32 pm
Wed Oct 17, 2018 6:37 am
Wed Oct 17, 2018 5:57 pm
Thu Oct 18, 2018 5:25 am
it's all good! I just don't want to see somebody miss their hunting season over a issue like that. roll that thing till you can get it fixed!!!!!!!
Thu Oct 18, 2018 3:36 pm
Sat Oct 20, 2018 11:46 am
I had on oil filled lower on my 07. You should be getting milky oil that quick. It will develop air bubbles and look different from running it, but not milky. I'm willing to bet you have the old 2 seal prop nut. I actually contacted PD and they swapped mine out to the newer style 3 seal prop nut for oil filled lowers for nothing, free of charge. Never had an issue after that.
Mon Oct 22, 2018 9:57 am
if I am understanding you correctly, the fitting to fill the lower unit is the same as a outboard motor lower unit. I just use an outboard lower unit pump/fitting to fill my pd lower unit when I had one. I don't know the exact thread size.
Mon Oct 22, 2018 1:52 pm
Shid just pout some earl in there!
Tue Oct 23, 2018 5:25 am
Tue Oct 23, 2018 1:13 pm
Fri Oct 26, 2018 11:53 am
Shooter, its the same prop nut only machined deeper to hold 3 seals. If you have a local machine shop, simply have them do it. Thats if it will be a while getting one from PD. And the seals are orientated a certain way. I don't quite remember which way though.
Mon Oct 29, 2018 3:44 am
they used to have u send in your nut with the 2 seals and they would send you the one with 3 seals in it. been a while since I did this.
Mon Oct 29, 2018 9:01 pm
They still do, just got my 3 seal nut from PD, sent my original back for just the price of the 3 seals.
Good deal.
Sun Nov 11, 2018 6:04 pm
