It is currently Sun Sep 21, 2025 1:41 pm
Reply to topic  [ 10 posts ]
 Lower Unit Gear Alignment
Post Lower Unit Gear Alignment
Hey guys, I have a 2006 Gen 1 lower unit and replaced the bearing in the upper, now am putting back together, should I line up the gears a certain way?. Is there a particular alignment to pay attention to?
Sat Mar 23, 2019 8:07 pm
Post Re: Lower Unit Gear Alignment
Here is a pic of the gear at head of prop shaft; it had the lower upper bearing for dinner whch I have now replaced. Think I should replace this gear also or anybody think its critical??
Thanks.
Sun Mar 24, 2019 4:22 pm
Replace it.
Sun Mar 24, 2019 5:31 pm
X2 on replace it
That's a problem waiting to happen
Support your troops. We support you.
B.
B. MacDonald
Sun Mar 24, 2019 5:34 pm
Roger that.
Sun Mar 24, 2019 6:09 pm
Yeah that needs replacing bad
Sun Mar 24, 2019 6:13 pm
PD no longer has this gear to order..it was made by curtis machine whhich no longer has them in inventory and does not make. Anybody know a machine shop that could reengineer? Or know somebody that may have Gen 1 LU with parts? Open to any ideas..?
Mon Mar 25, 2019 7:59 pm
Maybe you will get lucky and find someone with some parts. If not I bet having one made would be very expensive. If it was mine and I couldn't find some used parts I would run it, but plan on getting a new lower unit.
Tue Mar 26, 2019 6:06 pm
A good shop could repair that one for a couple hundred bucks.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Wed Mar 27, 2019 10:22 pm
maybe mudbuddy has some old pd clones u could buy from them, seeing as they stopped that goat roping and went on to copy gaytortail.
Sat Mar 30, 2019 5:43 pm
