It is currently Sun Sep 21, 2025 11:53 am
Reply to topic  [ 14 posts ]
 GDSD 35 Broke Shaft Lost Prop
Post GDSD 35 Broke Shaft Lost Prop
Getting towed back in now. I hit a log this morning and broke my shaft at the threads and lost the prop. I need another drive shaft and prop ASAP, but of course Go-devil and every dealership that I've called is closed today. Does anyone know of a dealership that carries replacement parts that's open today (12/26)?
Couldn't of broken down on a better spot though, got a 2 man limit quick and marked the spot. Lol
1654 Grizzly
'13 35 GDSD
"You should be more concerned with watching football than making chit fall out the sky!!!"
- My Wife
Mon Dec 26, 2016 9:46 am
Post Re: GDSD 35 Broke Shaft Lost Prop
Its unfortunate but Go devil dosent allow most parts to be in stock anywhere.. you have to call them, give vin#, then they ship you the parts.. plan on being down a few days
Mon Dec 26, 2016 10:32 am
If you have it apart, might try a machine shop in your area to build you a new one. Have had a local machine shop build all the replacement shafts that I've replaced in the last few years. Shafts are made of a better grade of steel, and hold up really well, and are a little cheaper. I'd replace all the seals and bearings while you have it apart.
Mon Dec 26, 2016 10:42 am
Yeah, I replaced everything in the lower unit 6 months ago except for the drive shaft and prop as the prop was still in pretty good shape. Guess I'll have to wait 'til tomorrow.
1654 Grizzly
'13 35 GDSD
- My Wife
Mon Dec 26, 2016 12:50 pm
Damn that looks just like my old gdsd when it broke the shaft and lost the prop... I found me prop though.
On making the shaft,,,, idk abt the gdsd but I was told that the longtail shaft has a twist to it like a torsion bar to absorb impact when the prop hit stuff. Maybe on the gdsd the belt takes the impact? I think the shaft for my gdsd was like $160 though but it might've been less.
Mon Dec 26, 2016 9:56 pm
It's not made into the shaft. So to speak. You're partially correct though. That shaft is made of EDT150, which has a good spring quality for a steel alloy. So yes, it absorbs torsional impacts pretty well. This is also the reason hitting a stuck prop with a hammer won't break it loose. ;)
-Custom pool noodle
-stage 4 water wings
Mon Dec 26, 2016 10:24 pm
I have a brand new big blade for GDSD
985-640-0569
Tue Dec 27, 2016 9:31 am
You have a 7/8" threaded mud buddy big blade?
-Custom pool noodle
Tue Dec 27, 2016 6:44 pm
yes 7/8 threaded big blade. fits GDSD
Sun Jan 01, 2017 9:09 am
Sun Jan 01, 2017 6:04 pm
Yeah, I have a new BB that I've only used twice. I'm probably going to sell it. I just like the 3 blade better for the long runs. Got my boat up and running again, $380 dollars later.
1654 Grizzly
'13 35 GDSD
- My Wife
Sun Jan 01, 2017 6:16 pm
I will post picture tomorrow with pitch and diameter. $260.00 new I had GDSD but switched to GT this year. Its sitting on shelf I have no use for it anymore. well. Hardly used it was my spare prop
Sun Jan 01, 2017 8:33 pm
New Member
Broke my shaft in the same spot, how did you pull the shaft out? Mines stuck in there pretty good
Sat Sep 14, 2019 10:47 am
New Member
Sat Sep 14, 2019 11:08 am
