It is currently Sat Nov 15, 2025 9:23 pm
Reply to topic  [ 5 posts ]
 Big block 25 get prop question.
Post Big block 25 get prop question.
I bought an extra prop when I picked up my rig at Delta performance. The stock prop is a two blade 10 pitch and the extra prop is a worked three blade 11 pitch. I run the three blade 11 most of the year. 3800 rpm's gives me good speed and handles a load well. This time of year I put the two blade ten on. It's thicker edges handle the hard stumps and other hard stuff better. It runs higher rpm's to achieve similar performance to the three blade...4300-4400. I keep it backed off most of the time. If I buy a two blade in a higher pitch (11) can I get my rpm's down and get better performance?
Thu Oct 21, 2021 10:09 am
Post Re: Big block 25 get prop question.
Title should read GTR...not get...
Thu Oct 21, 2021 10:11 am
Just get that 2 blade worked, add an inch of pitch, sharpen, balance, and that should bring your Rpms to around 3900-4100 and give you a little more on the top end if that’s the rpm range you are looking to achieve. Call baggy and he can take care of that for you. 985-868-0103
Fri Oct 22, 2021 6:37 am
Thanks. What's the turn around time on work like that?
Fri Oct 22, 2021 10:55 am
2-3 weeks bud
Sat Oct 23, 2021 8:33 am
